1 Reply Latest reply on Jan 28, 2007 5:37 PM by kglad
    How do you update an .SWF file with Javascript
      Hello - I have this Flash map that I've created. It uses javascript calls from within Flash to swap out hidden DIVS when a user clicks on a county. When the user clicks on the zip code region of that map, a javascript triggers the check box.
      What I need to do now is to have a way that when a user unclicks the check box, the zip code region in the map will be unhighlighted. Essentially, I need to have javascript tell a movie clip within the .SWF file to goto a certain frame and stop.
      I've never done this before, so I'm seeking someone's wisdom on how to proceed with this.
      For a visual on what I'm describing, the file can be viewed here:
