2 Replies Latest reply on Jan 28, 2007 6:07 AM by Newsgroup_User
    reloading XML data afert event - not working
    Bare_LV
      Hi, this is a Slide show AS. XML data is being parsed to an Array, and slideshow starts, and keeps going in loop.
      So far it's working fine, but I wan't to reload XML data (to check if there are newer images, [cause this is Standalone file]) after last element of the Array (picture) has been viewed. I spent two nights trying to solve this, but nothing happens. I mean, even after the XML file is updated, SWF keeps showing an old images. This must work without restarting the SWF player.
      Any ideas?
        • 1. Re: reloading XML data afert event - not working
          Peter Lorent Level 2
          Why is it that people strip the credits of the code they use? Your code should include:
          /* Crossfading slide show */
          /* Author: Todd Dominey */
          /* http://whatdoiknow.org */
          /* http://domineydesign.com */
          Now, you might have changed something but you shouldn't remove the credits!
          • 2. Re: reloading XML data afert event - not working
            Level 7
            I removed as much as I could, before posting it here. As you can see, my
            post is Looong enough anyway, and I was just afraid that people would not
            like to read through the long post.
            The problem stays the same.
            I've tried to copy this "xml.load" part into another function:
            images_xml = new XML();
            images_xml.ignoreWhite=true;
            images_xml.onLoad = parse;
            images_xml.load("images.xml");
            and then call this function from the function imageGen(data) that's checking
            if p==data.length.
            But it's not loading new pictures to the slideshow..
            Anyone knows why it's not working?
            Thanks.
            "LuigiL" <webforumsuser@macromedia.com> wrote in message
            news:epi6g5$f9l$1@forums.macromedia.com...
            > should
            > include:
            > credits!
