3 Replies Latest reply on Jan 24, 2007 7:57 AM by cf_dutch
    Weird Axis error CF 7.0.2
    cf_dutch Level 1
      I'm getting the following axis error when I try to invoke a webservice, hopefully someone here have seen this before...
      It seems that Axis can't write some sort of temp file in the temp folder. Any ideas?? (CF 7.0.2)
      Error
      Could not perform web service invocation "GetAllDomains".
      Here is the fault returned when invoking the web service operation:
      AxisFault
      faultCode: { http://schemas.xmlsoap.org/soap/envelope/}Server
      faultSubcode:
      faultString: Server was unable to process request. --> Unable to generate a temporary class (result=1).
      error CS2001: Source file 'C:\WINDOWS\TEMP\9tv05qt_.0.cs' could not be found
      error CS2008: No inputs specified
      faultActor:
      faultNode:
      faultDetail:
      { http://xml.apache.org/axis/}stackTrace:Server was unable to process request. --> Unable to generate a temporary class (result=1).
      at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:221)
      at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder.java:128)
      at org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:10 87)
      at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
      at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown S...
      Code
      <Cfinvoke method="GetAllDomains" webservice="#session.basepath#/svcDomainAdmin.asmx?WSDL" returnvariable="domains">
      120 : <Cfinvokeargument name="AuthUserName" value="#session.username#">
      121 : <Cfinvokeargument name="AuthPassword" value="#session.password#">
      122 : </cfinvoke>
      123 : <Cfset domainNames=domains.getDomainNames().getString()>
