11 Replies Latest reply on Jul 29, 2015 6:24 AM by Dallas Sacca
    cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
    dsbrady_98
      I'm developing with CF11 on a Mac, which doesn't support having a local PDF Service to use with the new tag. But, I'm able to set up a PDF service that points to our dev (Windows) server. That service verifies via the admin.
      However, when I try to do a simple test:
      <cfhtmltopdf>
          Hello
      </cfhtmltopdf>
      I get an error of "Error occurred while generating PDF" with the error detail of "Reason: FILE NOT FOUND". If we try this code directly on the dev server (so it's using the local PDF service), it works just fine.
      Anyone have an idea of what file it's referring to or what else may be going on?
        • 1. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
          Dallas Sacca
          I've run into a similar problem, but the error I get is "CANNOT CONNECT TO SERVER". The remote service request logs show a 400 error (bad request) but I'm not sure what is wrong. Have you made any progress with this issue?
          • 2. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
            Sandip_halder Adobe Employee
            Can you post a screenshot of the issue?
            • 3. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
              Dallas Sacca Level 1
              PDFG service request log:
              10.1.1.42 -  -  [23/Jul/2015:17:15:11 +0000] "POST /PDFgServlet/ HTTP/1.1" 500 319
              10.1.1.42 -  -  [23/Jul/2015:17:15:16 +0000] "POST /PDFgServlet/ HTTP/1.1" 200 -
              10.1.1.42 -  -  [23/Jul/2015:17:15:16 +0000] "POST /PDFgServlet/ HTTP/1.1" 400 331
              10.1.1.42 -  -  [23/Jul/2015:17:15:38 +0000] "POST /PDFgServlet/ HTTP/1.1" 400 331
              I've tried enabling logging in the PDFgServlet\WEB-INF\web.xml file but that just causes the remote service to crash.
              • 4. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
                Are you using ColdFusion 11 in Update 5? Are you able to register pdf service in the ColdFusion admin or do you get an error when clicking on verify connections?
                • 5. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
                  I am using ColdFusion 11 Update 5. I was able to register the pdf service and it verifies connections successfully.
                  • 6. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
                    I should mention that I installed the ColdFusion Add-on Services on a separate server from my ColdFusion 11 web server since I have a farm environment.
                    • 7. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
                      Was the installation of add on services successful? Could you please uninstall and reinstall the add on services?
                      • 8. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
                        The installation was successful. The Solr service is running correctly. Are there any other logs that I can check?
                        • 9. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
                          You can check in the exception and ColdFusion error logs
                          • 10. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
                            Below is all of the log data I've managed to scrape up in addition to the request log data posted earlier. If I could get more verbose logging from the PDFgServlet it might help but every time I've tried the service crashes. Any other ideas? Thanks.
                            coldfusion-out.log:
                            Jul 23, 2015 14:44:15 PM Warning [ajp-bio-8012-exec-4] - Thread: ajp-bio-8012-exec-4, processing template: \pdf.cfm, completed in 42 seconds, exceeding the 30 second warning limit
                            Jul 23, 2015 14:44:15 PM Error [ajp-bio-8012-exec-4] - Error occurred while generating PDF.Reason: CANNOT CONNECT TO SERVER The specific sequence of files included or processed is: \pdf.cfm, line: 1
                            exception.log:
                            "Error","ajp-bio-8012-exec-4","07/23/15","14:44:15",,"Error occurred while generating PDF.Reason: CANNOT CONNECT TO SERVER The specific sequence of files included or processed is: \pdf.cfm, line: 1 "
                            coldfusion.document.webkit.PDFgErrorHandler$ServiceManagerConversionException: Error occurred while generating PDF.
                              at coldfusion.document.webkit.PDFgErrorHandler.handleConversionError(PDFgErrorHandler.java:1 88)
                              at coldfusion.document.webkit.HttpPDFRequestHandler.requestPDFGeneration(HttpPDFRequestHandl er.java:170)
                              at coldfusion.tagext.lang.HtmlToPdfTag.processPDFgRequest(HtmlToPdfTag.java:1331)
                              at coldfusion.tagext.lang.HtmlToPdfTag.handlePDFgConversionRequest(HtmlToPdfTag.java:1466)
                              at coldfusion.tagext.lang.HtmlToPdfTag.convertToPDF(HtmlToPdfTag.java:1413)
                              at coldfusion.tagext.lang.HtmlToPdfTag.doEndTag(HtmlToPdfTag.java:1551)
                              at cfpdf2ecfm643596002.runPage(\\opscfdata01\data\dev\internalcf\moss\pdf.cfm:1)
                              at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:246)
                              at coldfusion.tagext.lang.IncludeTag.handlePageInvoke(IncludeTag.java:736)
                              at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:572)
                              at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
                              at coldfusion.filter.IpFilter.invoke(IpFilter.java:45)
                              at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:487)
                              at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:42)
                              at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
                              at coldfusion.filter.PathFilter.invoke(PathFilter.java:142)
                              at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:94)
                              at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:78)
                              at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
                              at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
                              at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:58)
                              at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
                              at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
                              at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62)
                              at coldfusion.CfmServlet.service(CfmServlet.java:219)
                              at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
                              at sun.reflect.GeneratedMethodAccessor76.invoke(Unknown Source)
                              at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                              at java.lang.reflect.Method.invoke(Unknown Source)
                              at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:277)
                              at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:274)
                              at java.security.AccessController.doPrivileged(Native Method)
                              at javax.security.auth.Subject.doAsPrivileged(Unknown Source)
                              at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:309)
                              at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:169)
                              at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:297)
                              at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:55 )
                              at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:191)
                              at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:187)
                              at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:186)
                              at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 )
                              at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
                              at sun.reflect.GeneratedMethodAccessor62.invoke(Unknown Source)
                              at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:249)
                              at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:237)
                              at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
                              at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
                              at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
                              at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
                              at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
                              at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
                              at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
                              at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:422)
                              at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:199)
                              at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.jav a:607)
                              at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
                              at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
                              at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
                              at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
                              at java.lang.Thread.run(Unknown Source)
                            server.log:
                            "Warning","ajp-bio-8012-exec-4","07/23/15","14:44:15",,"Thread: ajp-bio-8012-exec-4, processing template: \pdf.cfm, completed in 42 seconds, exceeding the 30 second warning limit"
                            • 11. Re: cfhtmltopdf with remote PDF service returning “FILE NOT FOUND”
                              Any ideas? I've tested this same scenario on another server farm and get the same results. Thanks.
