1 Reply Latest reply on Mar 30, 2015 5:54 PM by robdillon
    a problem with importing layered PSD file into Flash
    jaiwooo38480077
      Hi.
      There's a problem with importing layered PSD file into Flash.
      If I import a layered PSD file, some part the color of the lower layer is shown at the edge of objects or shadows. Instead, if I crop each layers first and import them, there's no problem.
      If the higher layer has brush or transparent effects, it becomes worse.
      Any help with this problem?
      Thanks.
        • 1. Re: a problem with importing layered PSD file into Flash
          robdillon Most Valuable Participant
          How was the original art created? Was the original RGB or CMYK? What is the resolution of the Photoshop file? Flash only works well with RGB and 72 pixel per inch resolution. If your original art is not set this way, then Flash will attempt to convert it as it imports it. Flash uses the sRGB color space. You'll get the best color translation if your Photoshop file is using this color preference.
