9 Replies Latest reply on Mar 31, 2015 5:30 PM by man9ar00
    How to correlate items in Illustrator document in GUI vs scripting objects?
    man9ar00 Level 1
      As a novice to Illustrator and Illustrator scripting. I notice that without good knowledge of Illustrator (the GUI and/or scripting), it's a bit tricky to correlate the type of item/object an item is as seen in the Illustrator GUI selecting the item on screen and/or seeing it in the layer's window. Because both of those don't indicate the matching Illustrator scripting item/object type, and I have to guess at what it is (or iteratively/recursively dump all items and see if I can figure out what is what from the dumped items from the script comparing to the info/properties in the UI).
      Or is there some mapping feature that will indicate this that I overlooked? If not, how best to correlate?
      As some examples:
      * how to figure out what type of object text is that we see in the Illustrator document (assume total novice, not knowing specific text types in Illustrator)
      * how to figure out whether a certain item in a layer is a page item, path item, or both? I can't tell.
