1 Reply Latest reply on Mar 30, 2015 2:20 PM by WolfShade
    RegEx data validation (server-side, not using CFFORM/CFINPUT)
    WolfShade Level 4
      Hello, everyone,
      I'm trying to use Regular Expressions on the server-side for data validation from a form.  I am not using CFFORM, so will not be using the validate attribute of the CFINPUT, etc.
      Basically, I've got the form being submit to the server via AJaX, and I'm using CFMatch() to check the input.
      The following works (inside CFSCRIPT tags):
      zipMask = "^\d{5}(-\d{4|)?$";
      if(arrayLen(REmatchNoCase(zipMask,form.zipCode)) eq 0){
          return "Zip Code is not in correct format.";
      So, if a user enters "12345-6789", it's considered valid.  If a user enters "12345&8765", it's not.
      What isn't working:
      coNameMask = "^[A-Za-z0-9]?$";
      if(arrayLen(REmatchNoCase(coNameMask,form.companyName)) eq 0){
          return "Company Name contains illegal characters.";
      This will return as an error no matter what I put in the field.
      Thoughts, suggestions?
