1 Reply Latest reply on Apr 20, 2015 1:10 AM by SilentWings
    Adobe CFC Generator error
    richardELeach Level 1
      Hi
      ... trying my hardest to make the CFC Generator work in CFB 3 but my error logs are filled with errors. The one in particular:
      Failed to install extension Adobe CFC Generator.zip -Directory "Adobe CFC Generator" already exists at install location
      ... and here is the stack trace:
      com.adobe.ide.coldfusion.appcodegeneration.install.ApplicationDirectoryExistException: Directory "Adobe CFC Generator" already exists at install location
        at com.adobe.ide.coldfusion.appcodegeneration.install.IDEInstallManager.extractZipFile(IDEIn stallManager.java:440)
        at com.adobe.ide.coldfusion.appcodegeneration.install.IDEInstallManager.installIDEApp(IDEIns tallManager.java:403)
        at com.adobe.ide.coldfusion.appcodegeneration.install.IDEInstallManager.install(IDEInstallMa nager.java:157)
        at com.adobe.ide.coldfusion.appcodegeneration.install.ExtensionInstallAction.install(Extensi onInstallAction.java:164)
        at com.adobe.ide.coldfusion.appcodegeneration.install.ExtensionInstallAction.access$1(Extens ionInstallAction.java:162)
        at com.adobe.ide.coldfusion.appcodegeneration.install.ExtensionInstallAction$1.run(Extension InstallAction.java:98)
        at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
      I uninstalled/reinstalled CFB 3 but I can not locate the directory on my machine where the previous Adobe CFC Generator already exists.
      Could this be an error with the installer/uninstaller?
      Rich
        • 1. Re: Adobe CFC Generator error
          SilentWings
          Open the Extension view: Window > Show View > Other > Extensions (under ColdFusion)
          In the Extension view select the Extension and then use the "view Details" button to get the location of the Extension.
          In my case this is C:\ColdFusionBuilder3\ColdFusion\cfusion\wwwroot\Adobe CFC Generator
          I am not sure if the extension is really working properly in CFB3 btw. (could not figure out how to define relations, etc.)
