8 Replies Latest reply on Jul 18, 2006 1:34 PM by ddanone
    Error compiling component from command line
    ddanone Level 1
      I have a folder "ctls" inside it i have a file called "Email.as" and looks like:
      package ctls
      import mx.controls.TextInput;
      import flash.events.Event;
      import mx.validators.EmailValidator;
      public class Email extends TextInput {
      public function Email() {
      When i try to make a component with the command line compiler compc
      i get the following error:
      C:\_tmp_\test_swc\ctls\Email.as: Error: A file found in an source-path must have
      the same package structure '', as the definition's package, 'ctls'.
      The comand line i execute is:
      compc -source-path+=ctls -debug=false -o=bin/mylib.swc Email
      How can i solve this?
      Thanks in advance
        • 1. Re: Error compiling component from command line
          Level 7
          Make sure that the "ctls" directory is in the source path.
          Easiest way to do this is to make sure that you are in the parent directory
          of "ctls" when calling compc. From you error message it looks like you
          should be calling compc from the c:\_tmp_\test_swc.
          Can you provide the compc call that you are using if this doesn't work..
          -brent
          "ddanone" <webforumsuser@macromedia.com> wrote in message
          news:e9h2l6$9e5$1@forums.macromedia.com...
          >like:
          > package ctls
          > When i try to make a component with the commandline compiler compc
          > must
          > have
          > Thanks in advance
          • 2. Re: Error compiling component from command line
            ddanone Level 1
            I'm compiling from the ctls parent folder:
            C:\_tmp_\test_swc\compc.exe -source-path+=ctls -debug=false -o=bin/mylib.swc Email
            ctls is under the test_swc folder
            • 3. Re: Error compiling component from command line
              Level 7
              The -source-path in this case should be "-source-path+=." instead of "ctls".
              C:\_tmp_\test_swc\compc.exe -source-path+=. -debug=false -o=bin/mylib.swc
              Email
              news:e9iriu$fes$1@forums.macromedia.com...
              > Email
              • 4. Re: Error compiling component from command line
                ddanone Level 1
                I get " Error: could not find source for class Email." with the command line
                Email
                • 5. Re: Error compiling component from command line
                  Level 7
                  My bad... you need to use the packaged name of the class to include:
                  ctls.Email
                  news:e9j378$pff$1@forums.macromedia.com...
                  >command line
                  > Email
                  • 6. Re: Error compiling component from command line
                    ddanone Level 1
                    if i use C:\_tmp_\test_swc\compc.exe -source-path+=. -debug=false -o=bin/mylib.swc
                    ctls.Email
                    then i get the same error: Error: could not find source for class ctls.Email.
                    I'm getting crazy!! On manuals it's easy but Adobe doesn't provide source samples to test the compc compiler.
                    • 7. Re: Error compiling component from command line
                      Level 7
                      So this is my setup:
                      Base directory = c:\flex\bugs\foobar
                      In here I have a directory called "ctls" which contains a simple class
                      called Emails.as (c:\flex\bugs\foobar\ctls\Email.as) that is in the ctls
                      package.
                      $ cd c:/flex/bugs/foobar
                      $ c:/flex/143452/gmc/bin/compc -source-path+=. -debug=false -o=foo.swc
                      ctls.Email
                      Loading configuration file C:\flex\143452\gmc\frameworks\flex-config.xml
                      C:\flex\bugs\foobar\foo.swc (1023 bytes)
                      news:e9j64b$t57$1@forums.macromedia.com...
                      > -o=bin/mylib.swc
                      > ctls.Email
                      > ctls.Email.
                      • 8. Re: Error compiling component from command line
                        ddanone Level 1
                        GREAT, NOW WORKS!!
                        Brent, thank you for your help
                        i'm going to post a comment on the online manual on the compc section showing a working example.
                        Thanks again!!
