0 Replies Latest reply on Mar 30, 2015 8:55 PM by Mirkoloko
    "aerendercore quit unexpectedly" PLZ help.
    Mirkoloko
      No link between AE and AME, can't render in AME... frustrating...
      Operating system:
      iMAC late 2014
      3,5 GHz Intel Core i7
      32 Go 1600 MHz DDR3
      NVIDIA GeForce GTX 780M 4096 Mo
      CUDA Driver Version: 7.0.29
      USING
      AE13.2 (last version)
      AME8.2 (last version)
      PROBLEM :
      When I try to render a comp from AE to Adobe Media Encoder in After Effect here's the warning that pop up :
      AME opens up, but don't have in queue the comp from AE.
      *It works perfectly from PP CC 2014 to AME
      but not from AE to AME.
      Here's the Details :
      Process:               aerendercore [4409]
      Path:                  /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/aerendercore.app/Contents/MacOS/aerendercore
      Identifier:            com.adobe.aerendercore
      Version:               13.2 (13.2)
      Code Type:             X86-64 (Native)
      Parent Process:        dynamiclinkmanager [1180]
      Responsible:           dynamiclinkmanager [1180]
      User ID:               501
      Date/Time:             2015-03-30 13:50:05.175 -0400
      OS Version:            Mac OS X 10.10.2 (14C1514)
      Report Version:        11
      Anonymous UUID:        A432561D-155D-7402-E0B4-9F682DF00278
      Time Awake Since Boot: 4500 seconds
      Crashed Thread:        0  Dispatch queue: com.apple.main-thread
      Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000008
      VM Regions Near 0x8:
          __TEXT                 0000000100000000-0000000100005000 [   20K] r-x/rwx SM=COW  /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/aerendercore.app/Contents/MacOS/aerendercore
      *Skip a part
      Logical CPU:     4
      Error Code:      0x00000004
      Trap Number:     14
      Binary Images:
          *Skip a part
      External Modification Summary:
        Calls made by other processes targeting this process:
          task_for_pid: 1
          thread_create: 0
          thread_set_state: 0
        Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
        Calls made by all processes on this machine:
          task_for_pid: 65919
          thread_create: 1
          thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=721.5M resident=352.3M(49%) swapped_out_or_unallocated=369.2M(51%)
      Writable regions: Total=4.6G written=65.6M(1%) resident=86.9M(2%) swapped_out=0K(0%) unallocated=4.6G(98%)
      REGION TYPE                      VIRTUAL
      ATS (font support)                 32.0M
      ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
      CG shared images                    144K
      CoreServices                         16K
      Dispatch continuations             16.0M
      IOKit                              4104K
      Image IO                           1628K
      Kernel Alloc Once                     8K
      MALLOC                            162.5M
      MALLOC (admin)                       32K
      Memory Tag 242                       12K
      Memory Tag 251                       32K
      STACK GUARD                        56.1M
      Stack                              21.3M
      VM_ALLOCATE                        44.2G
      VM_ALLOCATE (reserved)              4.2G        reserved VM address space (unallocated)
      __DATA                             60.8M
      __GLSLBUILTINS                     2588K
      __IMAGE                             528K
      __LINKEDIT                        210.9M
      __NV_CUDA                          5228K
      __TEXT                            510.6M
      __UNICODE                           544K
      mapped file                       197.4M
      shared memory                         4K
      TOTAL                              49.6G
      TOTAL, minus reserved VM space     45.4G
      Model: iMac14,2, BootROM IM142.0118.B09, 4 processors, Intel Core i7, 3.5 GHz, 32 GB, SMC 2.15f7
      Graphics: NVIDIA GeForce GTX 780M, NVIDIA GeForce GTX 780M, PCIe, 4096 MB
      Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
      Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
      Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
      Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x111), Broadcom BCM43xx 1.0 (7.15.159.13.12)
      Bluetooth: Version 4.3.2f6 15235, 3 services, 27 devices, 1 incoming serial ports
      Network Service: Wi-Fi, AirPort, en1
      PCI Card: pci1b4b,9182, AHCI Controller, Thunderbolt@193,0,0
      Serial ATA Device: APPLE SSD SM1024F, 1 TB
      USB Device: FaceTime HD Camera (Built-in)
      USB Device: BRCM20702 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: Hub
      USB Device: Apple LED Cinema Display
      USB Device: Display Audio
      USB Device: Display iSight
      USB Device: Keyboard Hub
      USB Device: Apple Keyboard
      USB Device: EDIROL UA-25
      Thunderbolt Bus: iMac, Apple Inc., 23.10
      Thunderbolt Device: G-DOCK ev With Thunderbolt, G-Technology, 3, 26.1
