2 Replies Latest reply on Mar 1, 2007 9:13 AM by Ninemill
    Flashpaper Text
      I need some help, if possible...
      I'm exporting a file from InDesign to PDF, then converting the PDF in FP to a Flashpaper document... every 10th line of text or so is really poor quality, like it is aliased or something... anyone else having an issue with this? Anyone have any suggestions?
        • 1. Re: Flashpaper Text
          res2cue Level 1
          Also... whenever I print the document, the same text that is poor quality on screen comes up hilighted in grey once printed. Thanks in advance.
          • 2. Re: Flashpaper Text
            Ninemill Level 1
            Not sure if you're having the same problem as me, but this is how I solved it:
            In Indesign, print your document using "postscript file" as the printer. Also, in 'graphics', change fonts to download: subset and then click save at the bottom.
            This should generate a .ps file which should then be converted into a pdf using Acrobat Distiller. This pdf should convert to FlashPaper without degrading the text.
            Hope that works,
