7 Replies Latest reply on Jan 24, 2007 3:20 PM by Newsgroup_User
    fade in - fade out bg loop
    gdmt
      hi everyone!
      i'm making a one on-off button to play-stop a bg loop.
      this is the timeline AS:
      setVolumen = function (soundObj, startLevel, maxLevel, inc) {
      soundObj.setVolume(startLevel);
      this.createEmptyMovieClip("loopSound", this.getNextHighestDepth());
      startLevel<maxLevel ? vol=inc : vol=-inc;
      this.loopSound.onEnterFrame = function() {
      startLevel += vol;
      if (soundObj.getVolume() == maxLevel) {
      delete loopSound.onEnterFrame;
      musica_ambiente = new Sound(this);
      musica_ambiente.attachSound("ambience");
      musica_ambiente.setVolume(0);
      musica_ambiente.start(0, 9999);
      setVolumen(musica_ambiente, 0, 50, 0.5);
      and this are the AS to control it:
      off:
      setVolumen(musica_ambiente, musica_ambiente.getVolume(), 0, 0.5);
      on:
      setVolumen(musica_ambiente, musica_ambiente.getVolume(), 10, 0.5);
      i don't know, i made 2 buttons and put'em inside a movieclip (one in the first frame, and the other in the second) and added'em the previous AS with gotoAndStop(1); and gotoAndStop(2); but it doesn't work...
      can someone help me to make it work?
      thanx a lot in advance!
      cheers!
        • 1. Re: fade in - fade out bg loop
          Level 7
          > off:
          > on:
          Once you in a movie clip, you no longer refer to the main timeline but the
          movie clip timeline. You need to _parent your function so it can find its
          way out of the movie clip. _parent will bring it one level up.
          Best Regards
          Urami
          !!!!!!! Merry Christmas !!!!!!!
          Happy New Year
          <urami>
          If you want to mail me - DO NOT LAUGH AT MY ADDRESS
          </urami>
          • 2. Re: fade in - fade out bg loop
            gdmt Level 1
            thanx 4 reply!
            yeah, i know urami_...
            i tried absolute and relative target paths...
            but... nothing...
            • 3. Re: fade in - fade out bg loop
              gdmt Level 1
              :S
              i'm triying to make it work but i can't...
              can someone check what's wrong?
              http://www.backupmyfiles.net/download.php?file=513491
              i'll really apreciate it...
              • 4. Re: fade in - fade out bg loop
                Level 7
                gdmt wrote:
                > thanx 4 reply!
                > but... nothing...
                Because the function sits on the _parent, and the musica_ambiente object sits on the _parent,
                you will need to use multiple _parent prefix in the path.
                _parent.setVolumen(_parent.musica_ambiente, _parent.musica_ambiente.getVolume(), 100, 0.5);
                However, you could create a function on the parent that makes the entire call:
                function fadeOutAmbiente() { setVolumen(musica_ambiente, musica_ambiente.getVolume(), 0, 0.5); }
                and then you'd just call that from the movieclip: _parent.fadeOutAmbiente();
                If you have several different sound objects on the same scope that you want to fade out from
                different scopes, you could go further and make a function like this:
                function fadeOut(soundName) { setVolumen(this[soundName], this[soundName].getVolume(), 0, 0.5); }
                and then you'd call it: _parent.fadeOut("musica_ambiente");
                Anyhow, I did some changes to your original code to prevent the multiple _parent references:
                setVolumen = function (soundName, maxLevel, inc) {
                var soundObj=this[soundName],
                startLevel=soundObj.getVolume();
                if (startLevel==maxLevel) return; // Abort if no change needed
                inc=Math.abs(inc)*(startLevel<maxLevel ? 1 : -1); // Enforce correct sign
                if (this.loopSound) this.loopSound.removeMovieClip(); // Kill old volume tween
                var mc=this.createEmptyMovieClip("loopSound", this.getNextHighestDepth()); // Create temp movieclip
                mc.onEnterFrame = function() {
                soundObj.setVolume(startLevel += inc);
                this.removeMovieClip(); // Kill temp movieclip
                setVolumen("musica_ambiente", 100, 0.5);
                Fade Out
                on (release) {
                _parent.setVolumen("musica_ambiente", 0, 0.5);
                Fade In
                on (release) {
                _parent.setVolumen("musica_ambiente", 100, 0.5);
                NOTE !!!
                It should now also fade nicely even if you click while another fade is in progress
                because it kill off the old one before creating the new.
                Best Regards
                Urami
                Happy New Year
                <urami>
                </urami>
                • 5. Re: fade in - fade out bg loop
                  gdmt Level 1
                  oh! thank you very much urami_ !!!
                  i'll check it!
                  :D
                  • 6. Re: fade in - fade out bg loop
                    gdmt Level 1
                    it worked perfectly!
                    thanx a lot urami_!!!
                    THANK YOU!
                    • 7. Re: fade in - fade out bg loop
                      Level 7
                      > THANK YOU!
                      You most Welcome :)
                      Sorry I did not reply earlier, I spent most of my time
                      on flash not flash.actionscript forum. Did not notice
                      the follow up.
                      Anyway, glad you got it working.
                      You have a nice day gdmt :)
                      Best Regards
                      Urami
                      Happy New Year
                      <urami>
                      </urami>
