• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Short Db Field
Participant ,
Jan 22, 2007 Jan 22, 2007
Hi..I have a db field called "sheetNo" it contains smth like "1,2,3,4,5,Cover,1B,2C,9,20,21 "
When short it by Asc or desc in my query, it doenst sort...what might be wrong ??
Thank u all..
TOPICS
Advanced techniques
Views
488
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
The problem is that you are storing numbers as text. When you do that '9' is greater than '10' .
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
Mentor ,
Depending on your database, you may be able to perform some gymnastics using CASE and functions to give you a sort order that is more in line with your expectations.
Example:
SELECT sheetNo
FROM your_table
WHERE whatever
ORDER BY CASE
WHEN IsNumeric(sheetNo) <> 0
THEN CAST(sheetNo AS NUMERIC)
ELSE 0 END,
UPPER(sheetNo)
Phil
Votes
Translate
Translate
Report
Report
Participant ,
I will try
Votes
Translate
Translate
Report
Report
Participant ,
Jan 23, 2007 Jan 23, 2007
I am using oracle..I think isnumeric is not an oracle function..what is the equivalent..
ORDER BY CASE WHEN IsNumeric(ctrDocs.sheetno)<> 0 THEN
cast(ctrDocs.sheetno AS NUMERIC) ELSE 0 END
Votes
Translate
Translate
Report
Report
LEGEND ,
to_number
Votes
Translate
Translate
Report
Report
Participant ,
I m still getting err.. What I am doing wrong..it is oracle..
ORDER BY CASE WHEN TO_NUMBER(ctrDocs.sheetno)<> 0 THEN
Votes
Translate
Translate
Report
Report
Mentor ,
Ah yes, Oracle. The to_number() function will throw an Oracle ORA-01722: invalid number error if you try to use it on anything non-numeric, so it really can't be used in this way because you have no way to trap the exception. Since there is no "native" isnumeric() function, you have to work around...
Borrowing from Oracle/PLSQL: Test a string for a numeric value, something like this might get you in the ballpark...
SELECT sheetNo
FROM ctrDocs
WHERE whatever
ORDER BY CASE
WHEN LENGTH(TRIM(TRANSLATE(ctrDocs.sheetno, '.0123456789',' '))) IS NULL
THEN CAST(ctrDocs.sheetno AS NUMBER)
ELSE 0 END, ctrDocs.sheetno
Phil
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Thank you all.
Votes
Translate
Translate
Report
Report
Resources
Documentation
