0 Replies Latest reply on Jan 20, 2007 12:57 PM by J3L
    Search engine
    J3L
      I am trying to create a search engine in flash mx and using an xml document to hold the search results. What i want it to do is for the user to enter something into the search field...the results come up and for them to click on a result and it taking them to a new frame or scene! i found a search engine tutorial online which does this, but it the results take u to an external URL not a new frame, and i cant figure out how to alter it to change this!!! any ideas from anyone? The XML document is as follows:
      Quote:
      <?xml version="1.0" ?>
      <bestof url=" http://www.kirupaforum.com/forums/forumdisplay.php?f=12">
      <post url=" http://www.kirupaforum.com/forums/showthread.php?t=43216">
      <title>xml menu DONE </title>
      </post>
      <post url=" http://www.kirupaforum.com/forums/showthread.php?t=51430">
      <title>Howd he do this? Resizing slideshow</title>
      </post>
      It just goes down a list like this of different values...and the action script is:
      Quote:
      String.prototype.contains = function(searchString){
      return (this.indexOf(searchString) != -1);
      Array.prototype.contains = function(searchValue){
      var i = this.length;
      while(i--) if (this == searchValue) return true;
      return false;
      SearchXML = function(nodes, query, useChildElements){
      var results = [];
      for (var i=0; i<nodes.length; i++){
      for (var j=0; j<nodes
      .childNodes.length; j++){
      currNode = nodes .childNodes[j];
      if (useChildElements.contains(currNode.nodeName)){
      if (currNode.firstChild.nodeValue.contains(query)){
      results.push(nodes
      break;
      return results;
      ElementsToSearch = function(){
      var childElementsToSearch = [];
      if (search_fields.title_check.checked){
      childElementsToSearch.push("title");
      return childElementsToSearch;
      DisplayNodes = function(nodes, field_txt){
      field_txt.htmlText = "";
      var entry;
      var separator = "<br>_______________________<br><br>";
      entry = "";
      entry += "<b>"+ nodes .childNodes[0].firstChild.nodeValue +"</b>";
      entry += "<br>"+ nodes
      .childNodes[2].firstChild.nodeValue;
      if (nodes .attributes.url.length){
      entry += "<a href='" + nodes
      .attributes.url;
      entry += "'><font color='#0000FF'>Read more...</font></a>";
      field_txt.htmlText += entry + separator;
      search_highlight = new TextFormat();
      search_highlight.color = 0xFF0000;
      search_highlight.italic = true;
      HighlightOccurences = function(str, field_txt, format){
      if (!str.length) return (0);
      var start = field_txt.text.indexOf(str);
      var end = start + str.length;
      while (start != -1){
      field_txt.setTextFormat(start, end, search_highlight);
      start = field_txt.text.indexOf(str, end);
      var posts_xml = new XML();
      posts_xml.ignoreWhite = true;
      posts_xml.onLoad = function(success){
      if (success){
      search_fields._visible = true;
      }else results_txt.text = "Error loading XML";
      search_fields._visible = false;
      posts_xml.load("bestofposts.xml");
      search_fields.title_check.title_txt.text = "Title";
      search_fields.search_btn.onRelease = function(){
      if (search_fields.query_txt.text.length < 3){
      results_txt.text = "Please use a search term with 3 or more characters.";
      return (0);
      var searchElements = ElementsToSearch();
      var nodesWithQuery = SearchXML(
      posts_xml.firstChild.childNodes,
      search_fields.query_txt.text,
      searchElements
      if (nodesWithQuery.length){
      DisplayNodes(
      nodesWithQuery,
      results_txt
      }else{
      results_txt.text = "No results for "+search_fields.query_txt.text+".";
      return (0);
      HighlightOccurences(
      results_txt,
      search_highlight
      What do i need to do!!??? Any help is greatly appreciated..
