2 Replies Latest reply on Jan 22, 2007 5:58 AM by robowriter
    Bug in Multi-File Search and Replace in RH6?
    robowriter
      I'm using the 6.0 trial, and one thing I want to be able to do is to replace the variables I put in using JavaScript with the new feature variables in 6.0. So, I went in to multi-file search and replace, and searched for:
      <script language=JavaScript>document.write(varProduct)</script>
      I copied this code directly from a topic, and pasted it into the Search tool.
      I don't even care whether I can successfully copy the code from my new variable for use as the replacement text; I'd be happy if the multi-file search would simply find all occurrences of my original code so I don't miss any during conversion to 6.0.
      It keeps coming up as not found, and this concerns me greatly. Has anyone else experienced this? Is it a known bug? Does anyone have a workaround?
      Thanks!
        • 1. Re: Bug in Multi-File Search and Replace in RH6?
          RoboWizard Level 4
          Hi robowriter
          I'm assuming you are using the wondrous little applet known as Multi-File Find and Replace.
          Unfortunately, this little beastie is like a cat. It frequently has a fussy tummy and loves to hork up furballs. Well, not exactly. Really what it does is fail to properly handle anything with a line break. So you need a tool that does do this. Fortunately, one exists! It is called FAR (Find And Replace). Oddly enough, it was also written by a fellow Microsoft Help MVP named Rob Chandler. (Rob lives in Australia)
          You can download a trial version of FAR from the FAR page. Click here to visit the FAR page
          Cheers... Rick
          • 2. Re: Bug in Multi-File Search and Replace in RH6?
            robowriter Level 1
            Your assumption is correct, Rick. Oddly, in an earlier test, Multi-File Find and Replace actually found the string. After a RoboHelp crash, however, it stopped finding the same string. I'll definitely check out FAR, though.
            As usual, I certainly appreciate your help!
            Cheers back...Carol
