19 Replies Latest reply on Apr 12, 2015 11:37 PM by cbuliarca
    Complicated script for Warp Transformation
    CapablancaYEAH
      Hello!
      I work in Printing and we have a little problem - our printer gives an arc-like distortion to images on canvas
      the distortion is like 1.8mm
      so we use Transform-Warp-Arc Upper and input the distortion value in %, manually on each layer (
      but this %value to make 1.8mm distortion differs from image to image
      e.g.  HxW  23.54x16.12 cm, value is -1.9%
             HxW 40.16x27.84 cm, value is -2.2%
      so wee put Guides and use Measure Tool to be sure about those 1.8mm
      i need:
      To write script, that will calculate the Warp-Upper Arc distorion %value (based on image size), to make this 1.8mm image correction, and then apply it to current selected layer
      Can someone help me please? In any way
      I`m very new to scripting T_T
        • 1. Re: Complicated script for Warp Transformation
          CapablancaYEAH Level 1
          So guys, i installed Script Listener, to see Warp tool settings, but i could get any mathematic formula for this process
          var desc3 = new ActionDescriptor();
                  var idHrzn = charIDToTypeID( "Hrzn" );
                  var idRlt = charIDToTypeID( "#Rlt" );
                  desc3.putUnitDouble( idHrzn, idRlt, 0.000000 );
                  var idVrtc = charIDToTypeID( "Vrtc" );
                  desc3.putUnitDouble( idVrtc, idRlt, 0.000000 );
              var idOfst = charIDToTypeID( "Ofst" );
              desc2.putObject( idOfst, idOfst, desc3 );
              var idwarp = stringIDToTypeID( "warp" );
                  var desc4 = new ActionDescriptor();
                  var idwarpStyle = stringIDToTypeID( "warpStyle" );
                  var idwarpArcUpper = stringIDToTypeID( "warpArcUpper" );
                  desc4.putEnumerated( idwarpStyle, idwarpStyle, idwarpArcUpper );
                  var idwarpValue = stringIDToTypeID( "warpValue" );
                  desc4.putDouble( idwarpValue, -1.800000 );
                  var idwarpPerspective = stringIDToTypeID( "warpPerspective" );
                  desc4.putDouble( idwarpPerspective, 0.000000 );
                  var idwarpPerspectiveOther = stringIDToTypeID( "warpPerspectiveOther" );
                  desc4.putDouble( idwarpPerspectiveOther, 0.000000 );
                  var idwarpRotate = stringIDToTypeID( "warpRotate" );
                  var idOrnt = charIDToTypeID( "Ornt" );
                  desc4.putEnumerated( idwarpRotate, idOrnt, idHrzn );
                  var iduOrder = stringIDToTypeID( "uOrder" );
                  desc4.putInteger( iduOrder, 4 );
                  var idvOrder = stringIDToTypeID( "vOrder" );
                  desc4.putInteger( idvOrder, 2 );
              desc2.putObject( idwarp, idwarp, desc4 );
          Do u have any ideas? How am i about to figure out the formula and where to place it?
          • 2. Re: Complicated script for Warp Transformation
            c.pfaffenbichler Level 9
            Worst case you could check the bounds, apply the operation, then have the Script check the bounds again and undo and retry with a new value until the height difference is roughly the intended 1,8mm.
            • 3. Re: Complicated script for Warp Transformation
              cbuliarca Level 3
              can you be more specific, from your problem I see that you need for every image with different WxH to distort the image with 1.8 mm, but from your example I see something else, because the first example truly gives an distortion of 1.8mm, the second one " HxW 40.16x27.84 cm, value is -2.2%" gives a distortion of 3.5mm not 1.8mm
              • 4. Re: Complicated script for Warp Transformation
                Hello cbuliarca!
                I really need 1.8mm distortion for every image ( no matter WxH)
                about that mistake - excuse me, misspelled it  seems, double-cheked HxW 40.16x27.84 cm  value should be -1.2%
                all images should be 127 dpi (if that matters)
                • 5. Re: Complicated script for Warp Transformation
                  So, mates, have someone come to a any solution? (((
                  • 6. Re: Complicated script for Warp Transformation
                    cbuliarca Level 3
                    I am digging now for 3-4 days, it's a hard one, till now I don't have a solution to find the percent, I'm still looking.... but to be honest I am really discouraged...
                    Any way maybe in the end I will take another approach and create a custom wrap, this is the easiest solution.
                    • 7. Re: Complicated script for Warp Transformation
                      Thank you for your time investment, bro!
                      If u feel thats hard, please do not go too deep into this and dont waste ur time! Cause im myself not sure if its solvable at all, i think that maybe just not worth it!
                      • 8. Re: Complicated script for Warp Transformation
                        cbuliarca Level 3
                        Don't worry about this, I'he managed to do some custom warp, I still have to clean and add some things, but the ideea is that maybe tomorrow I will have the script ready for you.
                        • 9. Re: Complicated script for Warp Transformation
                          Philip Cord Level 4
                          This seems to get close, I wonder if you could test it?
                          #target photoshop;
                          app.bringToFront();
                          main();
                          function main(){
                          if(!documents.length) return;
                          try{
                          var doc = app.activeDocument;
                          app.displayDialogs = DialogModes.NO;
                          var strtRulerUnits = app.preferences.rulerUnits;
                          var strtTypeUnits = app.preferences.typeUnits;
                          app.preferences.rulerUnits = Units.PIXELS;
                          app.preferences.typeUnits = TypeUnits.PIXELS;
                          var res = doc.resolution;
                          var inch = res;
                          var cm = inch / 2.54;
                          var mm = cm /10;
                          var warpFactor = mm * 1.8;
                          //$.writeln("1.8mm = " + warpFactor  + " pixels");
                          var bnds = doc.activeLayer.bounds;
                          var Height = bnds[3].value - bnds[1].value;
                          //$.writeln("Height = " + Height);
                          var warpValue = warpFactor/Height * 100;
                          //$.writeln("WarpValue = " + warpValue);
                          warpArcUpper(warpValue + (warpValue/1.75) );
                          }catch(e){
                          finally{
                          app.preferences.rulerUnits = strtRulerUnits;
                          app.preferences.typeUnits = strtTypeUnits;
                          function warpArcUpper(warpValue) {
                          var desc = new ActionDescriptor();
                          var ref = new ActionReference();
                          ref.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                          desc.putReference( charIDToTypeID('null'), ref );
                          desc.putEnumerated( charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), charIDToTypeID('Qcs6') );
                          var desc2 = new ActionDescriptor();
                          desc2.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Rlt'), 0.000000 );
                          desc2.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Rlt'), -0.000000 );
                          desc.putObject( charIDToTypeID('Ofst'), charIDToTypeID('Ofst'), desc2 );
                          desc.putUnitDouble( charIDToTypeID('Hght'), charIDToTypeID('#Prc'), 100 );
                          desc3.putEnumerated( stringIDToTypeID('warpStyle'), stringIDToTypeID('warpStyle'), stringIDToTypeID('warpArcUpper') );
                          desc3.putDouble( stringIDToTypeID('warpValue'), warpValue );
                          desc3.putDouble( stringIDToTypeID('warpPerspective'), 0.000000 );
                          desc3.putDouble( stringIDToTypeID('warpPerspectiveOther'), 0.000000 );
                          desc3.putEnumerated( stringIDToTypeID('warpRotate'), charIDToTypeID('Ornt'), charIDToTypeID('Hrzn') );
                          desc3.putInteger( stringIDToTypeID('uOrder'), 4 );
                          desc3.putInteger( stringIDToTypeID('vOrder'), 2 );
                          desc.putObject( stringIDToTypeID('warp'), stringIDToTypeID('warp'), desc3 );
                          desc.putEnumerated( charIDToTypeID('Intr'), charIDToTypeID('Intp'), charIDToTypeID('Bcbc') );
                          executeAction( charIDToTypeID('Trnf'), desc, DialogModes.NO );
                          Edit: No it doesn't work, but it did for a few tests.
                          So looking forward to the answer
                          • 10. Re: Complicated script for Warp Transformation
                            cbuliarca Level 3
                            Here is a script that creates a custom wrap, maybe before running it you can make the layer a smart object,
                            so you can see the wrap after.
                            function Vector(x, y){
                                this.x = x;
                                this.y = y;
                            Vector.prototype = {
                                add: function(other){
                                    if( other instanceof Vector){
                                        return new Vector(this.x + other.x, this.y + other.y);
                                    }else{
                                        return new Vector(this.x + parseFloat(other), this.y + parseFloat(other));
                                sub: function(other){
                                        return new Vector(this.x - other.x, this.y - other.y);
                                    }else{
                                        return new Vector(this.x - parseFloat(other), this.y - parseFloat(other));
                                mul: function(scalar){
                                    return new Vector(this.x * scalar, this.y * scalar);
                                mag: function(){
                                    return (Math.sqrt(this.x*this.x + this.y*this.y));
                                normalize: function(){
                                    vectorLength = this.mag();
                                    return new Vector(this.x/vectorLength, this.y/vectorLength);
                                dot:function (other){
                                    return other.x * this.x + other.y * this.y;
                                angle:function(other){
                                    rr = (Math.atan2((other.x-this.x),(this.y-other.y))) * (360.0/(2.0*Math.PI));
                                    qq = rr;
                                    return qq;
                                rotate:function( angle ){
                                    theta = angle * ((2.0*Math.PI)/360);// to radians
                                    cs = Math.cos(theta);
                                    sn = Math.sin(theta);
                                    px = this.x * cs - this.y * sn;
                                    py = this.x * sn + this.y * cs;
                                    return new Vector(px, py);
                                perpendicular:function(dir){// 1 or -1
                                    if(dir == 1){
                                        return new Vector(this.y, -this.x);
                                    }else{
                                        return new Vector(-this.y, this.x);
                            function Bezier(a, b, c, d) {
                                this.a = a;
                                this.b = b;
                                this.c = c;
                                this.d = d;
                                this.len = 500;//precision
                                this.arcLengths = new Array(this.len + 1);
                                this.arcLengths[0] = 0;
                                var ox = this.x(0);
                                var oy = this.y(0);
                                var clen = 0;
                                for(var i = 1; i <= this.len; i += 1) {
                                    var x = this.x(i/this.len), y = this.y(i/this.len);
                                    var dx = ox - x, dy = oy - y;
                                    clen += Math.sqrt(dx * dx + dy * dy);
                                    this.arcLengths[i] = clen;
                                    ox = x, oy = y;
                                this.length = clen;
                            Bezier.prototype = {
                                map: function(u) {
                                    var targetLength = u * this.arcLengths[this.len];
                                    var low = 0, high = this.len, index = 0;
                                    while (low < high) {
                                        index = low + (((high - low) / 2) | 0);
                                        if (this.arcLengths[index] < targetLength) {
                                            low = index + 1;
                                        } else {
                                            high = index;
                                    if (this.arcLengths[index] > targetLength) {
                                        index--;
                                    var lengthBefore = this.arcLengths[index];
                                    if (lengthBefore === targetLength) {
                                        return index / this.len;
                                    } else {
                                        return (index + (targetLength - lengthBefore) / (this.arcLengths[index + 1] - lengthBefore)) / this.len;
                                mx: function (u) {
                                    return this.x(this.map(u));
                                    // return this.x(u);
                                my: function (u) {
                                    return this.y(this.map(u));
                                    // return this.y(u);
                                x: function (t) {
                                    return ((1 - t) * (1 - t) * (1 - t)) * this.a.x
                                           + 3 * ((1 - t) * (1 - t)) * t * this.b.x
                                           + 3 * (1 - t) * (t * t) * this.c.x
                                           + (t * t * t) * this.d.x;
                                y: function (t) {
                                    return ((1 - t) * (1 - t) * (1 - t)) * this.a.y
                                           + 3 * ((1 - t) * (1 - t)) * t * this.b.y
                                           + 3 * (1 - t) * (t * t) * this.c.y
                                           + (t * t * t) * this.d.y;
                                tan:function(t){
                                    t = this.map(t);
                                    var C1x = ( this.d.x - (3.0 * this.c.x) + (3.0 * this.b.x) - this.a.x );
                                    var C2x = ( (3.0 * this.c.x) - (6.0 * this.b.x) + (3.0 * this.a.x) );
                                    var C3x = ( (3.0 * this.b.x) - (3.0 * this.a.x) );
                                    var C4x = ( this.a.x );
                                    var C1y = ( this.d.y - (3.0 * this.c.y) + (3.0 * this.b.y) - this.a.y );
                                    var C2y = ( (3.0 * this.c.y) - (6.0 * this.b.y) + (3.0 * this.a.y) );
                                    var C3y = ( (3.0 * this.b.y) - (3.0 * this.a.y) );
                                    var C4y = ( this.a.y );
                                    return new Vector((( 3.0 * C1x * t * t ) + ( 2.0 * C2x * t ) + C3x),(( 3.0 * C1y * t * t ) + ( 2.0 * C2y * t ) + C3y));
                                // http://blog.avangardo.com/2010/10/c-implementation-of-bezier-curvature-calculation/::
                                getDerivate:function(t){
                                    tSquared = t * t;
                                    s0 = -3 + 6 * t - 3 * tSquared;
                                    s1 = 3 - 12 * t + 9 * tSquared;
                                    s2 = 6 * t - 9 * tSquared;
                                    s3 = 3 * tSquared;
                                    resultX = this.a.x * s0 + this.b.x * s1 + this.c.x * s2 + this.d.x * s3;
                                    resultY = this.a.y * s0 + this.b.y * s1 + this.c.y * s2 + this.d.y * s3;
                                    return new Vector(resultX, resultY);
                                getSecondDerivate:function(t){
                                    s0 = 6 - 6 * t;
                                    s1 = -12 + 18 * t;
                                    s2 = 6 - 18 * t;
                                    s3 = 6 * t;
                                getCurvatureRadius:function(t){
                                    d1 = this.getDerivate(t);
                                    d2 = this.getSecondDerivate(t);
                                    r1 = Math.sqrt(Math.pow(d1.x * d1.x + d1.y * d1.y, 3));
                                    r2 = Math.abs(d1.x * d2.y - d2.x * d1.y);
                                    return r1 / r2;
                                toPSPath:function( add ){// true or false if I want to add the path
                                    //to psd path
                                    var lineArray3 = new Array()
                                    lineArray3[0] = new PathPointInfo
                                    lineArray3[0].kind = PointKind.CORNERPOINT
                                    lineArray3[0].anchor = Array(this.a.x, this.a.y)
                                    lineArray3[0].leftDirection = Array(this.b.x, this.b.y)
                                    lineArray3[0].rightDirection = Array(this.a.x, this.a.y)
                                    lineArray3[1] = new PathPointInfo
                                    lineArray3[1].kind = PointKind.CORNERPOINT
                                    lineArray3[1].anchor = Array(this.d.x, this.d.y)
                                    lineArray3[1].rightDirection = Array(this.c.x, this.c.y)
                                    lineArray3[1].leftDirection = Array(this.d.x, this.d.y)
                                    var lineSubPathArray = new Array()
                                    lineSubPathArray[0] = new SubPathInfo()
                                    lineSubPathArray[0].operation = ShapeOperation.SHAPEXOR
                                    lineSubPathArray[0].closed = false
                                    lineSubPathArray[0].entireSubPath = lineArray3
                                    if( add == true){
                                        var suffix = 0;
                                        for( var i=0; i<app.activeDocument.pathItems.length; i++){
                                            var pth = app.activeDocument.pathItems[i].name.toString();
                                            if( pth.search("BCM_Bezier_") != -1 ){
                                                var ss = pth.split("BCM_Bezier_");
                                                suffix = parseInt(ss[1]) + 1;
                                        var myPathItem = app.activeDocument.pathItems.add(("BCM_Bezier_"+suffix), lineSubPathArray);
                                        kk = app.activeDocument.pathItems.length -1;
                                        if(kk < 1){//no path to add to
                                            alert('no path to add to');
                                        }else{
                                            tcPthN = app.activeDocument.pathItems[kk].name;
                                            ttrgPthN = app.activeDocument.pathItems[kk - 1].name;
                                            // =======================================================select the new path
                                                var desc264 = new ActionDescriptor();
                                                    var ref206 = new ActionReference();
                                                    ref206.putName( charIDToTypeID( "Path" ), tcPthN );
                                                desc264.putReference( charIDToTypeID( "null" ), ref206 );
                                            executeAction( charIDToTypeID( "slct" ), desc264, DialogModes.NO );
                                            // =======================================================copy
                                            var idcopy = charIDToTypeID( "copy" );
                                            executeAction( idcopy, undefined, DialogModes.NO );
                                            // =======================================================select the targhet path
                                                    ref206.putName( charIDToTypeID( "Path" ), ttrgPthN );
                                            // =======================================================paste the paths
                                            var idpast = charIDToTypeID( "past" );
                                            executeAction( idpast, undefined, DialogModes.NO );
                                            // =======================================================delete the new path
                                            var idDlt = charIDToTypeID( "Dlt " );
                                                var desc48 = new ActionDescriptor();
                                                var idnull = charIDToTypeID( "null" );
                                                    var ref42 = new ActionReference();
                                                    ref42.putName( charIDToTypeID( "Path" ), tcPthN );
                                                desc48.putReference( idnull, ref42 );
                                            executeAction( idDlt, desc48, DialogModes.NO );
                                    }else{
                                        var suffix = 0;
                            // http://polymathprogrammer.com/downloads/bezierinterpolation.c
                            // http://polymathprogrammer.com/2007/06/27/reverse-engineering-bezier-curves/
                            function getControlPolyPoints( p0x, p0y, u,  p1x,  p1y, v,  p2x,  p2y, p3x,  p3y){
                                pos = [{x:0,y:0},{x:0,y:0},{x:0,y:0},{x:0,y:0}];
                                q1 = {x:0,y:0}
                                q2 = {x:0,y:0}
                                if ( (u<=0.0) || (u>=1.0) || (v<=0.0) || (v>=1.0) || (u>=v) ){
                                  return 0; /* failure */
                                a = 3*(1-u)*(1-u)*u;
                                b = 3*(1-u)*u*u;
                                c = 3*(1-v)*(1-v)*v;
                                d = 3*(1-v)*v*v;
                                det = a*d - b*c;
                                /* unnecessary, but just in case... */
                                if (det == 0.0){ return 0;} /* failure */
                                pos[0].x = p0x; pos[0].y = p0y;
                                pos[3].x = p3x; pos[3].y = p3y;
                                q1.x = p1x - ( (1-u)*(1-u)*(1-u)*p0x + u*u*u*p3x );
                                q1.y = p1y - ( (1-u)*(1-u)*(1-u)*p0y + u*u*u*p3y );
                                q2.x = p2x - ( (1-v)*(1-v)*(1-v)*p0x + v*v*v*p3x );
                                q2.y = p2y - ( (1-v)*(1-v)*(1-v)*p0y + v*v*v*p3y );
                                pos[1].x = d*q1.x - b*q2.x;
                                pos[1].y = d*q1.y - b*q2.y;
                                pos[1].x /= det;
                                pos[1].y /= det;
                                pos[2].x = (-c)*q1.x + a*q2.x;
                                pos[2].y = (-c)*q1.y + a*q2.y;
                                pos[2].x /= det;
                                pos[2].y /= det;
                                return pos; /* success */
                            // https://www.particleincell.com/2013/cubic-line-intersection/
                            function cubicRoots(P)
                                var a=P[0];
                                var b=P[1];
                                var c=P[2];
                                var d=P[3];
                                var A=b/a;
                                var B=c/a;
                                var C=d/a;
                                var Q, R, D, S, T, Im;
                                var Q = (3*B - Math.pow(A, 2))/9;
                                var R = (9*A*B - 27*C - 2*Math.pow(A, 3))/54;
                                var D = Math.pow(Q, 3) + Math.pow(R, 2);    // polynomial discriminant
                                var t=Array();
                                if (D >= 0)                                 // complex or duplicate roots
                                    var S = sgn(R + Math.sqrt(D))*Math.pow(Math.abs(R + Math.sqrt(D)),(1/3));
                                    var T = sgn(R - Math.sqrt(D))*Math.pow(Math.abs(R - Math.sqrt(D)),(1/3));
                                    t[0] = -A/3 + (S + T);                    // real root
                                    t[1] = -A/3 - (S + T)/2;                  // real part of complex root
                                    t[2] = -A/3 - (S + T)/2;                  // real part of complex root
                                    Im = Math.abs(Math.sqrt(3)*(S - T)/2);    // complex part of root pair
                                    /*discard complex roots*/
                                    if (Im!=0)
                                        t[1]=-1;
                                        t[2]=-1;
                                else                                          // distinct real roots
                                    var th = Math.acos(R/Math.sqrt(-Math.pow(Q, 3)));
                                    t[0] = 2*Math.sqrt(-Q)*Math.cos(th/3) - A/3;
                                    t[1] = 2*Math.sqrt(-Q)*Math.cos((th + 2*Math.PI)/3) - A/3;
                                    t[2] = 2*Math.sqrt(-Q)*Math.cos((th + 4*Math.PI)/3) - A/3;
                                    Im = 0.0;
                                /*discard out of spec roots*/
                                for (var i=0;i<3;i++)
                                    if (t[i]<0 || t[i]>1.0) t[i]=-1;
                                /*sort but place -1 at the end*/
                                t=sortSpecial(t);
                                // console.log(t[0]+" "+t[1]+" "+t[2]);
                                return t;
                            /*computes intersection between a cubic spline and a line segment*/
                            function computeIntersections(px,py,lx,ly)
                            // px is array of 4 bezier control points at x
                            // lx is array of the 2 points of the line at x
                                var X=Array();
                                var A=ly[1]-ly[0];      //A=y2-y1
                                var B=lx[0]-lx[1];      //B=x1-x2
                                var C=lx[0]*(ly[0]-ly[1]) +
                                      ly[0]*(lx[1]-lx[0]);  //C=x1*(y1-y2)+y1*(x2-x1)
                                var bx = bezierCoeffs(px[0],px[1],px[2],px[3]);
                                var by = bezierCoeffs(py[0],py[1],py[2],py[3]);
                                var P = Array();
                                P[0] = A*bx[0]+B*by[0];     /*t^3*/
                                P[1] = A*bx[1]+B*by[1];     /*t^2*/
                                P[2] = A*bx[2]+B*by[2];     /*t*/
                                P[3] = A*bx[3]+B*by[3] + C; /*1*/
                                var r=cubicRoots(P);
                                /*verify the roots are in bounds of the linear segment*/
                                returned = [];
                                    t=r[i];
                                    X[0]=bx[0]*t*t*t+bx[1]*t*t+bx[2]*t+bx[3];
                                    X[1]=by[0]*t*t*t+by[1]*t*t+by[2]*t+by[3];
                                    /*above is intersection point assuming infinitely long line segment,
                                      make sure we are also in bounds of the line*/
                                    var s;
                                    if ((lx[1]-lx[0])!=0)           /*if not vertical line*/
                                        s=(X[0]-lx[0])/(lx[1]-lx[0]);
                                    else
                                        s=(X[1]-ly[0])/(ly[1]-ly[0]);
                                    /*in bounds?*/
                                    if (t<0 || t>1.0 || s<0 || s>1.0)
                                        X[0]=-100;  /*move off screen*/
                                        X[1]=-100;
                                    returned.push({x:X[0], y:X[1]});
                                return returned;
                            function sortSpecial(a)
                                var flip;
                                var temp;
                                do {
                                    flip=false;
                                    for (var i=0;i<a.length-1;i++)
                                        if ((a[i+1]>=0 && a[i]>a[i+1]) ||
                                            (a[i]<0 && a[i+1]>=0))
                                            flip=true;
                                            temp=a[i];
                                            a[i]=a[i+1];
                                            a[i+1]=temp;
                                } while (flip);
                                return a;
                            // sign of number
                            function sgn( x )
                                if (x < 0.0) return -1;
                                return 1;
                            function bezierCoeffs(P0,P1,P2,P3)
                                var Z = Array();
                                Z[0] = -P0 + 3*P1 + -3*P2 + P3;
                                Z[1] = 3*P0 - 6*P1 + 3*P2;
                                Z[2] = -3*P0 + 3*P1;
                                Z[3] = P0;
                                return Z;
                            function warpUpperArcUntilMM( value ){
                                theDistnaceInPx = convertFromMMToPx( value );
                                W = parseFloat(app.activeDocument.width);
                                H = parseFloat(app.activeDocument.height);
                                var a1 = {x:0, y:0};
                                var m1 = {x:W/2, y:theDistnaceInPx};
                                var d1 = {x:W, y:0};
                                resC = getCubicBezierControlPointsWithCenterAt(a1, m1, d1);
                                var b1 = {x:resC[0][0], y:resC[0][1]};
                                var c1 = {x:resC[1][0], y:resC[1][1]};
                                mmBz = new Bezier(a1, b1, c1, d1);
                                //the Correction curve::
                                var a2 = {x:W*(1/3), y:0};
                                var b2 = {x:calculateFromProc(29.8142398589065,W), y:calculateFromProc(43.3226251146384,W/2)};
                                var c2 = {x:calculateFromProc(20.8158404938272,W), y:calculateFromProc(81.7067695238095, W/2)};
                                var d2 = {x:calculateFromProc(0.00000232804233,W), y:calculateFromProc(133.333328606702, W/2)};
                                sb2 = getControlPolyPoints( a2.x, a2.y, 0.433778236216,  b2.x, b2.y, 0.7,  c2.x, c2.y, d2.x, d2.y);
                                mmBz2Ref = new Bezier(sb2[0], sb2[1], sb2[2], sb2[3]);
                                // for the intersections:::
                                bmmBzPx = [mmBz2Ref.a.x,mmBz2Ref.b.x,mmBz2Ref.c.x, mmBz2Ref.d.x];
                                bmmBzPy = [mmBz2Ref.a.y,mmBz2Ref.b.y,mmBz2Ref.c.y, mmBz2Ref.d.y];
                                lPx = [0, mmBz.b.x];
                                lPy = [mmBz.b.y, mmBz.b.y];
                                inters = computeIntersections(bmmBzPx,bmmBzPy,lPx,lPy);
                                for( var a = 0; a<inters.length; a++){
                                    if( inters[a].x != -100){
                                        // addCountAt( inters[a].x,  inters[a].y);
                                        mmBz.b = {x:inters[a].x,  y:inters[a].y};
                                        mmBz.c = {x:W - inters[a].x,  y:inters[a].y};
                                // the vertical lines:
                                var al0 = {x:mmBz.b.x, y:mmBz.b.y};
                                var bl0 = {x:mmBz.b.x, y:mmBz.b.y};
                                var cl0 = {x:W*(1/3), y:H};
                                var dl0 = {x:W*(1/3), y:H};
                                var mmBzLine0 = new Bezier(al0, bl0, cl0, dl0);
                                var al1 = {x:mmBz.c.x, y:mmBz.c.y};
                                var bl1 = {x:mmBz.c.x, y:mmBz.c.y};
                                var cl1 = {x:W*(2/3), y:H};
                                var dl1 = {x:W*(2/3), y:H};
                                var mmBzLine1 = new Bezier(al1, bl1, cl1, dl1);
                                // the other 2 lines:
                                var a3 = {x:0,y:H*(1/3)};
                                var b3 = {x:mmBzLine0.mx(1/3),y:mmBzLine0.my(1/3)};
                                var c3 = {x:mmBzLine1.mx(1/3),y:mmBzLine1.my(1/3)};
                                var d3 = {x:W,y:H*(1/3)};
                                var mmBz1 = new Bezier(a3, b3,c3, d3);
                                var a4 = {x:0,y:H*(2/3)};
                                var b4 = {x:mmBzLine0.mx(2/3),y:mmBzLine0.my(2/3)};
                                var c4 = {x:mmBzLine1.mx(2/3),y:mmBzLine1.my(2/3)};
                                var d4 = {x:W,y:H*(2/3)};
                                var mmBz2 = new Bezier(a4, b4,c4, d4);
                                var a5 = {x:0,y:H};
                                var b5 = {x:W*(1/3),y:H};
                                var c5 = {x:W*(2/3),y:H};
                                var d5 = {x:W,y:H};
                                var mmBz3 = new Bezier(a5, b5,c5, d5);
                                bnds = {top:0, left:0, bottom:H, right:W};
                                points = [  mmBz.a, mmBz.b, mmBz.c, mmBz.d,
                                            mmBz1.a, mmBz1.b, mmBz1.c, mmBz1.d,
                                            mmBz2.a, mmBz2.b, mmBz2.c, mmBz2.d,
                                            mmBz3.a, mmBz3.b, mmBz3.c, mmBz3.d
                                warpTransf(bnds, points);
                            function calculateFromProc(val, relTo){
                                return (relTo*val)/100;
                            function calculateToProc(val, relTo){
                                return (100*val)/relTo;
                            function getCubicBezierControlPointsWithCenterAt( a, m, d ){
                                bx = (m.x - (1 - .75)* d.x) / .75;
                                by = (m.y - (1 - .75)* d.y) / .75;
                                cx = (m.x - (1 - .75)* a.x) / .75;
                                cy = (m.y - (1 - .75)* a.y) / .75;
                                pos = []
                                pos.push([bx, by]);
                                pos.push([cx, cy]);
                                return pos;
                            function convertFromMMToPx( mm ){
                                app.preferences.rulerUnits = Units.MM;
                                app.activeDocument.guides.add(Direction.HORIZONTAL, mm);
                                var PxVal = app.activeDocument.guides[app.activeDocument.guides.length -1 ].coordinate;
                                app.activeDocument.guides[app.activeDocument.guides.length -1 ].remove();
                                return parseFloat(PxVal);
                            function warpTransf(bounds, points){
                                var idTrnf = charIDToTypeID( "Trnf" );
                                    var desc259 = new ActionDescriptor();
                                    var idFTcs = charIDToTypeID( "FTcs" );
                                    var idQCSt = charIDToTypeID( "QCSt" );
                                    var idQcsa = charIDToTypeID( "Qcsa" );
                                    desc259.putEnumerated( idFTcs, idQCSt, idQcsa );
                                        var desc261 = new ActionDescriptor();
                                        var idwarpCustom = stringIDToTypeID( "warpCustom" );
                                        desc261.putEnumerated( idwarpStyle, idwarpStyle, idwarpCustom );
                                        desc261.putDouble( idwarpValue, 0.000000 );
                                        desc261.putDouble( idwarpPerspective, 0.000000 );
                                        desc261.putDouble( idwarpPerspectiveOther, 0.000000 );
                                        desc261.putEnumerated( idwarpRotate, idOrnt, idHrzn );
                                        var idbounds = stringIDToTypeID( "bounds" );
                                            var desc262 = new ActionDescriptor();
                                            var idTop = charIDToTypeID( "Top " );
                                            var idPxl = charIDToTypeID( "#Pxl" );
                                            desc262.putUnitDouble( idTop, idPxl, bounds.top );
                                            var idLeft = charIDToTypeID( "Left" );
                                            desc262.putUnitDouble( idLeft, idPxl, bounds.left );
                                            var idBtom = charIDToTypeID( "Btom" );
                                            desc262.putUnitDouble( idBtom, idPxl, bounds.bottom );
                                            var idRght = charIDToTypeID( "Rght" );
                                            desc262.putUnitDouble( idRght, idPxl, bounds.right );
                                        var idRctn = charIDToTypeID( "Rctn" );
                                        desc261.putObject( idbounds, idRctn, desc262 );
                                        desc261.putInteger( iduOrder, 4 );
                                        desc261.putInteger( idvOrder, 4 );
                                        var idcustomEnvelopeWarp = stringIDToTypeID( "customEnvelopeWarp" );
                                            var desc263 = new ActionDescriptor();
                                            var idmeshPoints = stringIDToTypeID( "meshPoints" );
                                                var list81 = new ActionList();
                                                    desc264.putUnitDouble( idHrzn, idPxl, points[0].x );
                                                    desc264.putUnitDouble( idVrtc, idPxl, points[0].y );
                                                var idrationalPoint = stringIDToTypeID( "rationalPoint" );
                                                list81.putObject( idrationalPoint, desc264 );
                                                    var desc265 = new ActionDescriptor();
                                                    desc265.putUnitDouble( idHrzn, idPxl, points[4].x );
                                                    desc265.putUnitDouble( idVrtc, idPxl, points[4].y );
                                                list81.putObject( idrationalPoint, desc265 );
                                                    var desc266 = new ActionDescriptor();
                                                    desc266.putUnitDouble( idHrzn, idPxl, points[8].x );
                                                    desc266.putUnitDouble( idVrtc, idPxl, points[8].y );
                                                list81.putObject( idrationalPoint, desc266 );
                                                    var desc267 = new ActionDescriptor();
                                                    desc267.putUnitDouble( idHrzn, idPxl, points[12].x );
                                                    desc267.putUnitDouble( idVrtc, idPxl, points[12].y );
                                                list81.putObject( idrationalPoint, desc267 );
                                                    var desc268 = new ActionDescriptor();
                                                    desc268.putUnitDouble( idHrzn, idPxl, points[1].x );
                                                    desc268.putUnitDouble( idVrtc, idPxl, points[1].y );
                                                list81.putObject( idrationalPoint, desc268 );
                                                    var desc269 = new ActionDescriptor();
                                                    desc269.putUnitDouble( idHrzn, idPxl, points[5].x );
                                                    desc269.putUnitDouble( idVrtc, idPxl, points[5].y );
                                                list81.putObject( idrationalPoint, desc269 );
                                                    var desc270 = new ActionDescriptor();
                                                    desc270.putUnitDouble( idHrzn, idPxl, points[9].x );
                                                    desc270.putUnitDouble( idVrtc, idPxl, points[9].y );
                                                list81.putObject( idrationalPoint, desc270 );
                                                    var desc271 = new ActionDescriptor();
                                                    desc271.putUnitDouble( idHrzn, idPxl, points[13].x );
                                                    desc271.putUnitDouble( idVrtc, idPxl, points[13].y );
                                                list81.putObject( idrationalPoint, desc271 );
                                                    var desc272 = new ActionDescriptor();
                                                    desc272.putUnitDouble( idHrzn, idPxl, points[2].x );
                                                    desc272.putUnitDouble( idVrtc, idPxl, points[2].y );
                                                list81.putObject( idrationalPoint, desc272 );
                                                    var desc273 = new ActionDescriptor();
                                                    desc273.putUnitDouble( idHrzn, idPxl, points[6].x );
                                                    desc273.putUnitDouble( idVrtc, idPxl, points[6].y );
                                                list81.putObject( idrationalPoint, desc273 );
                                                    var desc274 = new ActionDescriptor();
                                                    desc274.putUnitDouble( idHrzn, idPxl, points[10].x );
                                                    desc274.putUnitDouble( idVrtc, idPxl, points[10].y );
                                                list81.putObject( idrationalPoint, desc274 );
                                                    var desc275 = new ActionDescriptor();
                                                    desc275.putUnitDouble( idHrzn, idPxl, points[14].x );
                                                    desc275.putUnitDouble( idVrtc, idPxl, points[14].y );
                                                list81.putObject( idrationalPoint, desc275 );
                                                    var desc276 = new ActionDescriptor();
                                                    desc276.putUnitDouble( idHrzn, idPxl, points[3].x );
                                                    desc276.putUnitDouble( idVrtc, idPxl, points[3].y );
                                                list81.putObject( idrationalPoint, desc276 );
                                                    var desc277 = new ActionDescriptor();
                                                    desc277.putUnitDouble( idHrzn, idPxl, points[7].x );
                                                    desc277.putUnitDouble( idVrtc, idPxl, points[7].y );
                                                list81.putObject( idrationalPoint, desc277 );
                                                    var desc278 = new ActionDescriptor();
                                                    desc278.putUnitDouble( idHrzn, idPxl, points[11].x );
                                                    desc278.putUnitDouble( idVrtc, idPxl, points[11].y );
                                                list81.putObject( idrationalPoint, desc278 );
                                                    var desc279 = new ActionDescriptor();
                                                    desc279.putUnitDouble( idHrzn, idPxl, points[15].x );
                                                    desc279.putUnitDouble( idVrtc, idPxl, points[15].y );
                                                list81.putObject( idrationalPoint, desc279 );
                                            desc263.putList( idmeshPoints, list81 );
                                        desc261.putObject( idcustomEnvelopeWarp, idcustomEnvelopeWarp, desc263 );
                                    desc259.putObject( idwarp, idwarp, desc261 );
                                executeAction( idTrnf, desc259, DialogModes.NO );
                            app.activeDocument.suspendHistory("bcmWarpCustomUpperArc", "warpUpperArcUntilMM( 1.8 )");
                            • 11. Re: Complicated script for Warp Transformation
                              Philip Cord Level 4
                              Just tested your code on windows 7 and Photoshop cs6 and it dosen't make any change whatsoever to the layer, no arc at all.
                              • 12. Re: Complicated script for Warp Transformation
                                cbuliarca Level 3
                                It's wierd, I've just tested the code I've posted on a mac in Cs6 and also in windows7 and cs6 and it works fine. Maybe you are testing it on a locked Background layer?  Does it gives any errors?
                                • 13. Re: Complicated script for Warp Transformation
                                  cbuliarca Level 3
                                  I've modified the script to work with CS4 as well:
                                      this.x = x;
                                      this.y = y;
                                          }else{
                                          }else{
                                      mag: function(){
                                          qq = rr;
                                          return qq;
                                          if(dir == 1){
                                          }else{
                                      this.a = a;
                                      this.b = b;
                                      this.c = c;
                                      this.d = d;
                                      var ox = this.x(0);
                                      var oy = this.y(0);
                                      var clen = 0;
                                          ox = x, oy = y;
                                      this.length = clen;
                                      map: function(u) {
                                                  low = index + 1;
                                              } else {
                                                  high = index;
                                              index--;
                                          } else {
                                      mx: function (u) {
                                      my: function (u) {
                                      x: function (t) {
                                      y: function (t) {
                                      tan:function(t){
                                          t = this.map(t);
                                          tSquared = t * t;
                                          s3 = 3 * tSquared;
                                          s0 = 6 - 6 * t;
                                          s1 = -12 + 18 * t;
                                          s2 = 6 - 18 * t;
                                          s3 = 6 * t;
                                          return r1 / r2;
                                          //to psd path
                                          if( add == true){
                                              var suffix = 0;
                                              }else{
                                          }else{
                                              var suffix = 0;
                                      q1 = {x:0,y:0}
                                      q2 = {x:0,y:0}
                                      b = 3*(1-u)*u*u;
                                      d = 3*(1-v)*v*v;
                                      det = a*d - b*c;
                                      pos[1].x /= det;
                                      pos[1].y /= det;
                                      pos[2].x /= det;
                                      pos[2].y /= det;
                                      var a=P[0];
                                      var b=P[1];
                                      var c=P[2];
                                      var d=P[3];
                                      var A=b/a;
                                      var B=c/a;
                                      var C=d/a;
                                      var t=Array();
                                          if (Im!=0)
                                              t[1]=-1;
                                              t[2]=-1;
                                          Im = 0.0;
                                      t=sortSpecial(t);
                                      return t;
                                      var X=Array();
                                      var P = Array();
                                      returned = [];
                                          t=r[i];
                                          var s;
                                          else
                                          /*in bounds?*/
                                              X[1]=-100;
                                      return returned;
                                      var flip;
                                      var temp;
                                      do {
                                          flip=false;
                                                  flip=true;
                                                  temp=a[i];
                                                  a[i]=a[i+1];
                                                  a[i+1]=temp;
                                      } while (flip);
                                      return a;
                                  // sign of number
                                  function sgn( x )
                                      return 1;
                                      var Z = Array();
                                      Z[3] = P0;
                                      return Z;
                                      var a5 = {x:0,y:H};
                                      var d5 = {x:W,y:H};
                                      pos = []
                                      pos.push([bx, by]);
                                      pos.push([cx, cy]);
                                      return pos;
                                      return (mm*(app.activeDocument.resolution/25.4));
                                  • 14. Re: Complicated script for Warp Transformation
                                    Philip Cord Level 4
                                    I have just tested both scripts and neither work for me. I checked the bounds for the height of the layer before and after running the scripts and there was no difference. I ran mine ant it did create the arc.
                                    I also tried runing both scripts without the suspend history, every run of the scripts didn't produce any errors at all.
                                    Very strange.
                                    Edit:
                                    I saved the script and watched it in Photoshop, before I was running it from ESTK. I can now see that it is doing a curve but it is doing a LOWER not upper curve, that why the bounds were returning the same height.
                                    • 15. Re: Complicated script for Warp Transformation
                                      cbuliarca Level 3
                                      Yes, actually that's what CapablancaYEAH nedded an interior arc, from his firts post I see that he uses -1.9.
                                      I can adjust the script to go upper as well....
                                      • 16. Re: Complicated script for Warp Transformation
                                        Philip Cord Level 4
                                        It's me not reading it right! I must do better next time! Sorry for confusing matters.
                                        • 17. Re: Complicated script for Warp Transformation
                                          Dear friends!
                                          Thank u very much for your help !
                                          But i must tell, that our printing machine is having pretty bad failure times now.
                                          Instead of constantly makin 1.8mm distorion it now gives various, unpredictable, depending of document width
                                          So i think there is no sense making script anymore (( cause it has became too complicated, unsolvable
                                          Excuse me, friends (
                                          • 18. Re: Complicated script for Warp Transformation
                                            cbuliarca Level 3
                                            Ok, no problem , just to let you know the scrpt I've done can receve arguments, so you can alawys change the amount of distortion.
