1 Reply Latest reply on Apr 2, 2015 10:30 PM by BKBK
    Path to CFC Not Working on new domain
    Emily LaMunyon Level 1
      Hello,
      I have some .cfc's that reside in the same directory as the .cfm file calling them. Everything works as expected, but now we are changing the structure of our web site and cfc paths are not working. I have spent hours trying to figure this out and still no solution.
      The current (working) path to the cfc is:
      wwwroot/data/historical/stateplane/select.cfc
      with the domain looking like this:
      http://surveyor.website.org/data/historical/stateplane/select.cfc
      We are changing our the structure to, (which throws an error when looking for the cfc):
      wwwroot/surveyor/data/historical/stateplane/select.cfc
      with the domain changing to:
      http://website.org/surveyor/data/historical/stateplane/select.cfc
      The sel_stateplane.cfm page has the following code calling the cfc, which lives in the same directory:
      <cfselect name="TOWNSHIP_RANGE" bind="cfc:select.getTownship()" bindonload="true" value="TOWNSHIP_RANGE" display="TOWNSHIP_RANGE" />
      But with the added /surveyor folder after the root, it no longer works. I have tried to path it out like this with no luck, I get a 500 error:
      <cfselect name="TOWNSHIP_RANGE" bind="cfc:surveyor.data.historical.stateplane.select.getTownship()" bindonload="true" value="TOWNSHIP_RANGE" display="TOWNSHIP_RANGE" />
      Any help would be appreciated!
        • 1. Re: Path to CFC Not Working on new domain
          BKBK Adobe Community Professional & MVP
          The original code should still work, provided the CFC remains in the same directory as the calling page. This one: <cfselect name="TOWNSHIP_RANGE" bind="cfc:select.getTownship()" bindonload="true" value="TOWNSHIP_RANGE" display="TOWNSHIP_RANGE" />. That is because the relative path remains unchanged.
          Temporarily change the name of the application (in Application.cfc) to ensure the application restarts. ColdFusion will then have to recompile.
