2 Replies Latest reply on Mar 31, 2015 4:57 PM by LMallare
    Why aren't my motion paths visible?
    LMallare
      I went through the steps to create a motion path but the actual path is not visible to edit. Is there a setting that needs to be adjusted?
        • 1. Re: Why aren't my motion paths visible?
          VivekP Adobe Employee
          Hello,
          If you were able to create the motion path successfully then you can make the path visible by selecting the element (that you had selected to apply motion path) on the stage. If it do not show any motion path then check if any transition is created in timeline for that element or not as it should be there.
          Please look at the screenshot below.
          if the transition and motion path are not there, it means that you missed one step.
          you can check the video below to make sure you are doing it correctly. If this is not the case please let me know we will look for more possibilities.
          Edge Animate CC : Motion Paths - YouTube
          Regards
          Vivek
          • 2. Re: Why aren't my motion paths visible?
            LMallare Level 1
            Thank you,
            Vivek. For some reason, when I right-clicked on the element and selected “Use
            Motion Paths”, the animation was created but there was no motion path. When I
            clicked “Motion Path” in the Properties window, an editable motion path was
            created.
            I appreciate your help!
