17 Replies Latest reply on Apr 1, 2015 6:56 AM by JamesHaney
    Display document data in dialog box
    JamesHaney
      I am using a folder level script to do the following:
      Get a specific XMP field value from an open PDF file:
      this.info.InDesignFileName
      Define a dialog box
      Create a menu item that calls the dialog box
      But for the life of me, I cannot get the dialog creation function to populate the XMP value into a static text item.
      The function below is modified from the example right out of the Acrobat Javascript API Reference.
      var inDesignNameDialog = {
      initialize: function (dialog) {
      // store InDesignFileName XMP
      //var indfn = this.info.InDesignFileName
      // Create a static text containing the current date.
      /*var todayDate = dialog.store()["date"];
      todayDate = "Date: " + util.printd("mmmm dd, yyyy", new Date());
      dialog.load({ "date": todayDate });
      var todayDate = dialog.store()["indfn"];
      currFN = "Date: " + this.info.InDesignFileName;
      dialog.load({ "indfn": currFN });
      commit:function (dialog) { // called when OK pressed
      var results = dialog.store();
      // Now do something with the data collected, for example,
      console.println("Your name is " + results["fnam"]
      + " " + results["lnam"] );
      description:
      name: "Personal Data", // Dialog box title
      align_children: "align_left",
      width: 350,
      height: 200,
      elements:
      type: "cluster",
      elements:
      type: "view",
      align_children: "align_row",
      elements:
      type: "static_text",
      name: "First Name: "
      item_id: "fnam",
      type: "edit_text",
      alignment: "align_fill",
      width: 300,
      height: 20
      type: "view",
      elements:
      name: "Last Name: "
      item_id: "lnam",
      type: "edit_text",
      width: 300,
      height: 20
      name: "InDesign File Name: ",
      char_width: 50,
      item_id: "indfn"
      alignment: "align_right",
      type: "ok_cancel",
      ok_name: "Ok",
      cancel_name: "Cancel"
