Is there a way to do this? Right now, the user has to select the correct answer to get to the next slide, but they can just click on the "next" button on the play bar and that will advance them to the next screen. I was hopeful there on an "on enter" action that would disable to "next" button on the playbar, but all I can seem to do is hide the play bar during the quiz. That isnt helpful in the even the user wants to go backwards. Any suggestions? I am using Captivate 8. Thanks in advance.
Why not hide the playbar, and if you want to let the user go backwards, simply keep the "Back" button on each question slide?
I didnt even think of that. Thank you, I will give that a try 🙂
Cool! Hope it works well
I tried this, but when the user goes back to the previous slide(not a quiz slide) the playbar disables on that slide as well(it does have the playbar before I go to the next slide and click "back"). The "on exit" on the first quiz slide is disabled so I cannot say "on exit" show playbar. Is there a way around this?
Hmm...If the slide that it's going back to is not a quiz slide, I'm surprised that it would disable the playbar there since it should only do that during the quiz slides. Weird...
I just tried it and it works for me! How strange!
When you go back to the previous slide before the quiz, the playbar appears? That is strange. I wondered if it might have just been because I was previewing within Captivate so I published and it is doing the same thing for me. The playbar disappears on the slide before the quiz when I click the "back" button I added. What version of Captivate are you using?
