1 Reply Latest reply on Apr 2, 2015 6:05 PM by jfb00
    cfc connection
    jfb00 Level 3
      Hi All,
      I copy a flex project into a new laptop. I configured the same environment.Now cfcs are not working. I can see the gateway file with data services but when I test a function I am getting this error:
      Reason: java.io.IOException: Server returned HTTP response code: 500 for URL: http://localhost:8500/flex2gateway/
      If i check this address on the browser i see this error message:
      ava.lang.NullPointerException
          at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:285)
          at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
          at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
          at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
          at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
          at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
          at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      I usually work with ColdFusion remote Object connection but this project is not using that.
      Any ideas how to fix this issue?
