I've installed Photoshop Elements 12 from a CD onto my PC laptop. I'm thinking about buying a tablet, so was wondering if (a) can I install on a 2nd device (b) can I use the serial number online as I won't beable to install from a CD, and (c) will I beable to choose a mac, after the initial was on a PC???? Thanks Martin
A single user license allows for having activated installations on two machines. An Elements license allows for either platform in many cases (recently not the case from what I've seen). If you have the disc, see if it contains the Mac installation files... if it does then you should be able to install them via a download as well. I cannot answer with certainty for the last question since it relies on the previous question. Personally, I would not let an inexpensive piece of software dictate
...Copy link to clipboard
A single user license allows for having activated installations on two machines. An Elements license allows for either platform in many cases (recently not the case from what I've seen). If you have the disc, see if it contains the Mac installation files... if it does then you should be able to install them via a download as well. I cannot answer with certainty for the last question since it relies on the previous question. Personally, I would not let an inexpensive piece of software dictate an expensive hardware purchase decision.
Cheers Ned, the Elements box came with 2 CD's, a PC and a Mac version so in theory I should be OK, but I guess your last comment makes sense. Thanks Martin
