OK - I'm about at my wit's end. I am running Cp 8.0.145 (I know, .245 is current, but my IT guys need to vet it before I get it) on a Win7 desktop and trying to publish a .zip file to an Adobe Connect system functioning as an LMS. I do not have full admin rights to the Connect instance. I have tried publishing the Captivate projects using the "Adobe Connect" setting (with and without "Publish Adobe Connect metadata" box selected), as an AICC compliant zip file, and as a SCORM 2004 v4 package, and as a SCORM 2004 v4 package in a wrapper provided by Adobe. In each and every case, the system does not register any value for the test questions included (shows a test value of 0/0) and will not register completion of the course on passing the test.
Is this an issue with my settings in Captivate when I publish, or something I need to address with the LMS admin for Connect?
Justenuf
A bit old...
I don't think Connect does SCORM, so take that out of the mix.
It might do AICC, so that may be worth trying.
But overall, of course, you want to use the Adobe Connect setting...and I'm certain you want to include the Connect metadata.
If it's not reporting then you should ask the Connect Admin to look at logs/reports and see if he can find any reason why. Setup a time to test and run through the piece, so he knows what date/time to look for...
Hopefully he has access to Connect logs that will show whatever the errors may be.
Seen these?
https://helpx.adobe.com/captivate/using/connect.html
Publishing Captivate content to Adobe Connect - Adobe Connect User Community
Erik:
Thanks for the follow up - we were able to address our issues with Connect through a conversion wrapper for our non-Captivate source files and the errors regarding our responsive design files were ironed out with the Admin.
Justenuf
Great! Glad you got it worked out
can you please tell me how did you solve this issue ?
