11 Replies Latest reply on Apr 2, 2015 11:55 AM by JenLedger
    JavaScript works in Pro but not Reader - NotAllowedError
    JenLedger
      I have created a web form in Adobe XI Pro. We have some progress bars at the top with number of fields completed type of thing. All of my JavaScript works perfectly in Acrobat. I save it like so Save As Other > Reader Extended PDF > Enable More Tools. Again everything works in Acrobat. When I open the PDF in Reader the JavaScript won't work. My forms still fill I can save and such, but no JavaScript progress bars. We create this form frequently and it has always worked. I assume it is some sort of new update to Adobe XI Pro. Here is the error I receive in the debugger:
      NotAllowedError: Security settings prevent access to this property or method.
      Doc.title:27:Document-Level:Progress
      I was thinking it might be related to the security settings these are the only 2 things not allowed.
      Document Assembly : Not Allowed
      Page Extraction: Not Allowed
      But as I read through the forums I am not sure that is actually the problem. Any ideas?
      Thanks in advance,
      Jen
        • 1. Re: JavaScript works in Pro but not Reader - NotAllowedError
          George_Johnson MVP & Adobe Community Professional
          Can you post the code you're using for the progress bar?
          • 2. Re: JavaScript works in Pro but not Reader - NotAllowedError
            JenLedger Level 1
            //Define all required fields
            this.first = this.getField("FirstName");
            this.family = this.getField("FamilyName");
            this.addressOne = this.getField("AddressOne");
            this.addressTwo = this.getField("AddressTwo");
            //Load them all into an array
            this.REQUIRED = [first, family, addressOne, addressTwo ];
            //Define the colors to be used
            this.gray = ["RGB", 0.208, 0.208, 0.208];
            this.amber = ["RGB", 0.992, 0.905, 0];
            this.red = ["RGB", 0.937, 0.282, 0.212];
            this.green = ["RGB", 0.431, 0.710, 0.016];
            //Call the document-level functions to update the Checklist
            updateAll();
            function updateAll()
              Dupdate();
            //Updates the P46 entry.
            /*----------------NEW-------------------*/
            function Dupdate()
              this.DfieldCount = 0
              this.DnumComplete = 0;
              //Get all required fields in the form -----------
              var first = this.getField("FirstName");
              var family = this.getField("FamilyName");
              var addressOne = this.getField("AddressOne");
              var addressTwo = this.getField("AddressTwo");
              var dFields = [first, family, addressOne, addressTwo];
              //Check required fields for completion and visibility
              for (var i in dFields)
              if (dFields[i].display == display.visible)
              this.DfieldCount++;
              if (dFields[i].value != "" && dFields[i].name != "ReceiveCopy")
              this.DnumComplete++;
              if(dFields[i].name == "ReceiveCopy")
              if(dFields[i].value == "Yes" || dFields[i].value == "No")
              var t = this.getField("PFortySix");
              if (DnumComplete == 0)
              t.fillColor = this.gray;
              this.getField("DProgress").userName = "";
              else if (DnumComplete < DfieldCount)
              t.fillColor = this.amber;
              else
              t.fillColor = this.green;
              this.getField("DProgress").value = this.DnumComplete + "/" + this.DfieldCount;
              if (this.DnumComplete == this.DfieldCount) this.getField("DProgress").userName = "Done";
            • 3. Re: JavaScript works in Pro but not Reader - NotAllowedError
              The error message is from something else, because in this code the title
              property is never accessed, so it could not cause this error message.
              • 4. Re: JavaScript works in Pro but not Reader - NotAllowedError
                JenLedger Level 1
                • 5. Re: JavaScript works in Pro but not Reader - NotAllowedError
                  Bernd Alheit Adobe Community Professional & MVP
                  Look at line 27 of function Progress.
                  • 6. Re: JavaScript works in Pro but not Reader - NotAllowedError
                    The first lines in that screenshot do not correspond to the first lines of the code you posted. Post the full code.
                    • 7. Re: JavaScript works in Pro but not Reader - NotAllowedError
                      JenLedger Level 1
                      //Turn off the warnings when JavaScript is enabled
                      this.getField("JavascriptWarning").display = display.visible;
                      this.getField("ProgressTracking").display = display.visible;
                      //Required fields warning
                      this.alerted = false;
                      this.postcodeOne = this.getField("Postcode-1");
                      this.daytimeTelephone = this.getField("DaytimeTelephone");
                      this.payrollReference = this.getField("PayrollReference");
                      //---P46
                      this.nationalOne = this.getField("NationalInsurance1");
                      this.nationalTwo = this.getField("NationalInsurance2");
                      this.nationalThree = this.getField("NationalInsurance3");
                      this.nationalFour = this.getField("NationalInsurance4");
                      this.nationalFive = this.getField("NationalInsurance5");
                      this.nationalSix = this.getField("NationalInsurance6");
                      this.nationalSeven = this.getField("NationalInsurance7");
                      this.nationalEight = this.getField("NationalInsurance8");
                      this.nationalNine = this.getField("NationalInsurance9");
                      this.title = this.getField("Title");
                      this.surnameOne = this.getField("SurnameFamilyName-1");
                      this.firstOne = this.getField("FirstorGivenName-1");
                      this.dobOne = this.getField("DOB-1");
                      this.dobTwo = this.getField("DOB-2");
                      this.dobThree = this.getField("DOB-3");
                      this.dobFour = this.getField("DOB-4");
                      this.dobFive = this.getField("DOB-5");
                      this.dobSix = this.getField("DOB-6");
                      this.dobSeven = this.getField("DOB-7");
                      this.dobEight = this.getField("DOB-8");
                      this.houseOne = this.getField("HouseOrFlatNumber-1");
                      this.restAddressOne = this.getField("RestOfAddress-1");
                      this.dateOne = this.getField("Date-1");
                      //---Leidos Employee Bank Details For Payroll
                      this.employeeNumber = this.getField("EmployeeNumber");
                      this.bankName = this.getField("BankName");
                      this.bankAddressOne = this.getField("BankAddressOne");
                      this.bankAddressTwo = this.getField("BankAddressTwo");
                      this.bankPostcodeOne = this.getField("BankPostcode-1");
                      this.bankSortCodeOne = this.getField("BankSortCode-1");
                      this.bankAccountNumber = this.getField("BankAccountNumber-1");
                      this.effectiveDate = this.getField("EffectiveDate");
                      //---Baseline Personnel Security Standard
                      this.birthPlace = this.getField("PlaceOfBirth");
                      this.birthNationality = this.getField("NationalityAtBirth");
                      this.presentNationality = this.getField("PresentNationality");
                      this.REQUIRED = [first, family, addressOne, addressTwo, postcodeOne, daytimeTelephone, payrollReference, nationalOne, nationalTwo, nationalThree, nationalFour, nationalFive, nationalSix, nationalSeven, nationalEight, nationalNine, title, surnameOne, firstOne, dobOne, dobTwo, dobThree, dobFour, dobFive, dobSix, dobSeven, dobEight, houseOne, restAddressOne, dateOne, employeeNumber, bankName, bankAddressOne, bankAddressTwo, bankPostcodeOne, bankSortCodeOne, bankAccountNumber, effectiveDate, birthPlace, birthNationality, presentNationality ];
                      updateAll();
                        Dupdate();
                        EOWupdate();
                        LNHupdate();
                        EBDupdate();
                        BPSSupdate();
                      function Dupdate()
                        //Get all required fields in the form ----------- ecFirst, ecNationalOne
                        var postcodeOne = this.getField("Postcode-1");
                        var nationalOne = this.getField("NationalInsurance1");
                        var nationalTwo = this.getField("NationalInsurance2");
                        var nationalThree = this.getField("NationalInsurance3");
                        var nationalFour = this.getField("NationalInsurance4");
                        var nationalFive = this.getField("NationalInsurance5");
                        var nationalSix = this.getField("NationalInsurance6");
                        var nationalSeven = this.getField("NationalInsurance7");
                        var nationalEight = this.getField("NationalInsurance8");
                        var nationalNine = this.getField("NationalInsurance9");
                        var title = this.getField("Title");
                        var surnameOne = this.getField("SurnameFamilyName-1");
                        var firstOne = this.getField("FirstorGivenName-1");
                        var dobOne = this.getField("DOB-1");
                        var dobTwo = this.getField("DOB-2");
                        var dobThree = this.getField("DOB-3");
                        var dobFour = this.getField("DOB-4");
                        var dobFive = this.getField("DOB-5");
                        var dobSix = this.getField("DOB-6");
                        var dobSeven = this.getField("DOB-7");
                        var dobEight = this.getField("DOB-8");
                        var houseOne = this.getField("HouseOrFlatNumber-1");
                        var restAddressOne = this.getField("RestOfAddress-1");
                        var dateOne = this.getField("Date-1");
                        var dFields = [postcodeOne, nationalOne, nationalTwo, nationalThree, nationalFour, nationalFive, nationalSix, nationalSeven, nationalEight, nationalNine, title, surnameOne, firstOne, dobOne, dobTwo, dobThree, dobFour, dobFive, dobSix, dobSeven, dobEight, houseOne, restAddressOne, dateOne];
                        this.DfieldCount++;
                        else
                      //Updates the Leidos Expression of Wish entry.
                      function EOWupdate()
                        this.EOWfieldCount = 0
                        this.EOWnumComplete = 0;
                        //Get all required fields in the form ----------- ecFirst, ecFamily, ecAddressOne, ecAddressTwo, ecPostcodeOne, ecNationalOne
                        var daytimeTelephone = this.getField("DaytimeTelephone");
                        var payrollReference = this.getField("PayrollReference");
                        var eowFields = [first, family, addressOne, addressTwo, postcodeOne, daytimeTelephone, payrollReference, nationalOne, nationalTwo, nationalThree, nationalFour, nationalFive, nationalSix, nationalSeven, nationalEight, nationalNine, dobOne, dobTwo, dobThree, dobFour, dobFive, dobSix, dobSeven, dobEight ];
                        for (var i in eowFields)
                        if (eowFields[i].display == display.visible)
                        this.EOWfieldCount++;
                        if (eowFields[i].value != "")
                        this.EOWnumComplete++;
                        var t = this.getField("ExpressionWish");
                        if (EOWnumComplete == 0)
                        this.getField("EOWProgress").userName = "";
                        else if (EOWnumComplete < EOWfieldCount)
                        else
                        this.getField("EOWProgress").value = this.EOWnumComplete + "/" + this.EOWfieldCount;
                        if (this.EOWnumComplete == this.EOWfieldCount) this.getField("EOWProgress").userName = "Done";
                      //Updates the Leidos Limited New Hires entry.
                      function LNHupdate()
                        this.LNHfieldCount = 0
                        this.LNHnumComplete = 0;
                        var lnhFields = [first, family ];
                        for (var i in lnhFields)
                        if (lnhFields[i].display == display.visible)
                        this.LNHfieldCount++;
                        if (lnhFields[i].value != "")
                        this.LNHnumComplete++;
                        var t = this.getField("LimitedNewHires");
                        if (LNHnumComplete == 0)
                        else if (LNHnumComplete < LNHfieldCount)
                        else
                        this.getField("LNHProgress").value = this.LNHnumComplete + "/" + this.LNHfieldCount;
                        if (this.LNHnumComplete == this.LNHfieldCount) this.getField("LNHProgress").userName = "Done";
                        else this.getField("LNHProgress").userName = "";
                      //Updates the Leidos Employee Bank Details for Payroll entry.
                      function EBDupdate()
                        this.EBDfieldCount = 0
                        this.EBDnumComplete = 0;
                        var employeeNumber = this.getField("EmployeeNumber");
                        var bankName = this.getField("BankName");
                        var bankAddressOne = this.getField("BankAddressOne");
                        var bankAddressTwo = this.getField("BankAddressTwo");
                        var bankPostcodeOne = this.getField("BankPostcode-1");
                        var bankSortCodeOne = this.getField("BankSortCode-1");
                        var bankAccountNumber = this.getField("BankAccountNumber-1");
                        var effectiveDate = this.getField("EffectiveDate");
                        var ebdFields = [first, family, employeeNumber, bankName, bankAddressOne, bankAddressTwo, bankPostcodeOne, bankSortCodeOne, bankAccountNumber, effectiveDate ];
                        for (var i in ebdFields)
                        if (ebdFields[i].display == display.visible)
                        this.EBDfieldCount++;
                        if (ebdFields[i].value != "")
                        this.EBDnumComplete++;
                        var t = this.getField("EmployeeBankDetails");
                        if (EBDnumComplete == 0)
                        else if (EBDnumComplete < EBDfieldCount)
                        else
                        this.getField("EBDProgress").value = this.EBDnumComplete + "/" + this.EBDfieldCount;
                        if (this.EBDnumComplete == this.EBDfieldCount) this.getField("EBDProgress").userName = "Done";
                        else this.getField("EBDProgress").userName = "";
                      //Updates the Baseline Personnel Security Standard entry.
                      function BPSSupdate()
                        this.BPSSfieldCount = 0
                        this.BPSSnumComplete = 0;
                        var birthPlace = this.getField("PlaceOfBirth");
                        var birthNationality = this.getField("NationalityAtBirth");
                        var presentNationality = this.getField("PresentNationality");
                        var bpssFields = [first, family, addressOne, addressTwo, postcodeOne, daytimeTelephone, dobOne, dobTwo, dobThree, dobFour, dobFive, dobSix, dobSeven, dobEight, birthPlace, birthNationality, presentNationality];
                        for (var i in bpssFields)
                        if (bpssFields[i].display == display.visible)
                        this.BPSSfieldCount++;
                        if (bpssFields[i].value != "")
                        this.BPSSnumComplete++;
                        var t = this.getField("Baseline");
                        if (BPSSnumComplete == 0)
                        else if (BPSSnumComplete < BPSSfieldCount)
                        else
                        this.getField("BPSSProgress").value = this.BPSSnumComplete + "/" + this.BPSSfieldCount;
                        if (this.BPSSnumComplete == this.BPSSfieldCount) this.getField("BPSSProgress").userName = "Done";
                        else this.getField("BPSSProgress").userName = "";
                      • 8. Re: JavaScript works in Pro but not Reader - NotAllowedError
                        OK, now it's more clear. There's a built-in property of the Document object
                        called title, so you can't define your own property with that name
                        (especially not if you're trying to apply a Field object to it, as it is a
                        String).
                        • 9. Re: JavaScript works in Pro but not Reader - NotAllowedError
                          Adobe Reader can't change the property title of the document.
                          • 10. Re: JavaScript works in Pro but not Reader - NotAllowedError
                            As noted "this.title" cannot be altered by Reader. See the "X" in the 4th box of the Quick Bar. The same holds true for this.info[Title].
