I was unable to find a phrase I was looking for in my
RoboHelp X5 project with RoboHelp's Multi-File Find and Replace
tool. I was searching for "Change button" which I knew was there,
because I could see it in the WYSIWYG editor. I was thinking that
it might be an issue with Microsoft Visual Studio source control
since I use that tool for version control. So I made certain that
all my files were checked in, then searched again, and Multi-File
Find and Replace still couldn't find the phrase. I downloaded FAR (
http://helpware.net/FAR/index.html)
as suggested on this forum, but that tool couldn't find the phrase
either. I tried searching the output (FlashHelp) but there's no
Boolean search capability like there is in WebHelp, so a search for
"Change button" resulted in a number of topics that was the
equivalent of an "OR" search. I even searched through the RoboHelp
files in Windows Explorer and still couldn't find what I knew was
there.
Finally, I discovered why. I highlighted "Change button" in
the topic and looked at the html code in the True Code editor and
found: <span style="font-weight: bold;">Change</span>
button.<span style="font-weight: bold;">. Evidently
Multi-File Find and Replace is not searching the WYSIWYG. (On the
Multi-File Find and Replace tool's dialog I even made sure to use
*.* in the Named field to search all files, not just html).
Does anyone have a solution to this? Shouldn't the Multi-File
Find and Replace tool be searching the WYSIWYG?
Thanks!
Gina
