3 Replies Latest reply on Jan 24, 2007 9:46 AM by asdi;fuhy
    styles don't show up
    asdi;fuhy
      Hi. I'm new to the list, though not to Robo etc.
      I want to select Expanding Text from the style drop-down, but it's not there. It's in the list you see when you click Format/Styles though. Why doesn't it display in the Styles dropdown?
      Also, I want to customize the Expanding Text style (in Format/Styles dialog). But the Modify/Paragraph is greyed out. Why won't it let me indent this style?
      Thanks for any help you can give me.
      Mike
        • 1. Re: styles don't show up
          Welcome to the forum.
          You add expanding text via the DHTML menu after selecting the hotspot and the style is automatically applied. I can't see why you would want to select it from the style menu.
          You should be able to modify the style by opening the style sheet in a style sheet editor such as Top Style or plain old Notepad.
          • 2. Re: styles don't show up
            Level 1
            Expanding text is inserted via the DHTML menu, as Peter indicated; that's why you can't select it from the Style drop-down menu. You can't indent the paragraph for the style because expanding text is designed to come immediately after a word. It isn't a separate paragraph; the text is inserted into the current paragraph. Because Expanding Text is a character style, you can't customize any paragraph properties.
            It sounds like you might find the Drop-Down Text style more useful. The text is designed to come after the paragraph that contains the drop-down link, so you can indent it and customize it like any other paragrph style.
            • 3. Re: styles don't show up
              asdi;fuhy Level 1
              Thanks, I was all balled up having forgotten the difference between expanding text and dropdown.
              Mike
