2 Replies Latest reply on Apr 3, 2015 8:15 AM by rob day
    Why can't I use a pure blue RGB (0,0,255)?
    dcm279
      Why can't I use a pure blue RGB (0,0,255)? When I set this color it automatically changes to this muted blue RGB(56,82,164)!
        • 1. Re: Why can't I use a pure blue RGB (0,0,255)?
          SJRiegel Adobe Community Professional & MVP
          My best guess is that you have a CMYK document, so you are getting CMYK color, and that is the closest equivalent in that color space.
          • 2. Re: Why can't I use a pure blue RGB (0,0,255)?
            If you turn on either Overprint or Separation Preview the color previews in the document's CMYK space:
            You can see that Overprint is turned on in my title bar
            InDesign documents don't have a color space—you can have a mix of RGB, CMYK, Lab, and grayscale objects. However, if there's transparency anywhere on the page the document's Transparency Blend Space is used for the preview and flattening on export or output and that can be either RGB or CMYK
            CMYK blend space:
            RGB Blend Space:
