7 Replies Latest reply on Jun 16, 2015 3:05 PM by _keyframer
    Video from SWF file
    rahex
      I need to get my animations from Flash Pro CC into a nice crisp looking video clip.
      When I use the option in Flash Pro File - Export- Export Video, I do get a video file. But it looks a bit too blurry. The SWF file itself is much crispier.
      When I use the workflow with After Effects, described here https://forums.adobe.com/thread/1328048, the picture is much more crisp, but I lose the parts in the animation witch were not on the timeline, but coded and also I lose all nested animations (like blinking with eyes etc.).
      How could I use the workflow – Flash – After Effects – Premier Pro, but without losing the coded animations in SWF file and the nested animations?
        • 1. Re: Video from SWF file
          robdillon Most Valuable Participant
          There are many reasons why your video looks soft. It may be the video output settings, or it may be the publish settings in Flash. Is your original artwork all done in Flash as vectors, or have you imported bitmap art from Photoshop?
          What settings are you using to encode the video?
          • 2. Re: Video from SWF file
            Asymetrical Adobe Community Professional
            Also unless I'm wrong if the video is not playing the nested animation it might be because the symbols are movie clips. switch it to a graphics clip and they'll play on export.
            • 3. Re: Video from SWF file
              rahex Level 1
              Robin,
              the export settings in flash are as they are - there is not much choice. The stage is 800x480.
              The artwork is all as vectors.
              In Adobe Encoder is used the settings H264 HD 720 23.976.
              Asymetrical,
              The eye blinks are done with shape tweens.
              When importing the SWT into After Effects I lose also the movieClips that are added to the stage during playback, with code.
              They are in SWF. But when importing into AE, they are gone.
              And also some movieClips that are moving along the stage with code, are standing still in AE.
              • 4. Re: Video from SWF file
                If you change the size of the image or the aspect ratio or the frame rate from the Flash version to the video version, then you are going to be altering the image.
                • 5. Re: Video from SWF file
                  Well there's at least some of your trouble. You can NOT export a movie clip with code to a video. it won't work, which is probably WHY your movie is blank in the first place. Especially if you're asking that code to place movie clips onto the stage. Forgive me if I missed you explaining this in the beginning.
                  The way movie export works in Flash is almost like taking a screen capture sequence (although not exactly). But basically, what plays live in real time on the stage is what will export. SO, if you want to export your file as a video you'll have to place those movie clips on the stage yourself, set frame ranges for how long they need to play and then make sure the clips animate on the stage in real time. Personally we use Graphic symbols and NOT movie clips and I don't believe they export well to a video.
                  • 6. Re: Video from SWF file
                    rahex Level 1
                    I changed the size of the stage to the expected size of the video and the outcome is acceptable.
                    Asymetrical - it is possible to export a video having it perform with code, not only with timeline. I did it. Using movie clips.
                    Maybe with graphic symbols the video would be even more crisp, but with this project it is to much work to do that change.
                    • 7. Re: Video from SWF file
                      _keyframer Adobe Community Professional
                      Just to add to the discussion, I author a lot of Flash animation for video format and I always start off with my Flash stage size set to 1920x1080 and export to this same dimension.
