1 Reply Latest reply on Dec 18, 2006 1:54 PM by Newsgroup_User
    cfobject component
    romeogq Level 1
      My components are located in a level 1 subdirectory named cfcs.
      In my root directory I have a test script (test.cfm), and in a level 1 subdirectory named other I have my actual script (actual.cfm).
      This <cfobject component="cfcs.logfunctions" name="logs"> works for the root test file, or at least I don't generate an error, but not for my actual file located in the subdirectory. What the problem?
      Error on Actual Subdirectory File:
      Could not find the ColdFusion Component cfcs.logfunctions. Please check that the given name is correct and that the component exists.
        • 1. Re: cfobject component
          Level 7
          CF looks for components in the current directory and subdirectories of
          it. To use components outside of this path, one needs to create mapping
          in the cfadministrator. Create a mapping named "CFCS" pointing to your
          CFCS directory and all will work fine.
