0 Replies Latest reply on Apr 4, 2015 2:33 AM by OzSanta2
    Illustrator won't direct print edited document with Applescript.
    OzSanta2
      G'day
      I've struck a problem where edited documents won't print using Applescript direct printing, instead generating a 'can't print illustration' error.
      The error message is untrappable in Applescript.
      My code, with the direct print commented out, is ...
      Does anyone know how to direct print an edited document, please?
      Regards
      Santa
      property theLargePagePrinter : "Quark Printer"
      property tempName : "test"
      property diditPrint : false
      property PreserveFileName : "This is the name part"
      property largePaperSize : "A4"
      my printIllustrator()
      on printIllustrator()
        try
        set TempAttachmentName to "(2015 03  05 121212Z)"
        tell application "Adobe Illustrator"
        try
        activate
        tell current application to delay 0.1
        set addBarCode to false
        tell application "Finder"
        set my tempName to "This is a test" as text
        end tell
        repeat 2 times
        try
        tell application "System Events" to tell process "Adobe Illustrator"
        click button "Continue" of window 1
        end tell
        end try
        end repeat
        set x to 0
        repeat until exists document 1
        set x to x + 1
        end repeat
        if my tempName does not contain "_UEI ftpSaving" then set addBarCode to true
        set p to 1
        if addBarCode then
        set p to 1.1
        set bb to visible bounds of document 1
        set p to 2
        set PaperSize to crop marks of document 1
        set p to 3
        tell document 1
        set p to 4
        set n to number of layers
        repeat with x from 1 to n
        set p to 5
        set locked of layer x to false
        end repeat
        end tell
        set p to 6
        # Text Frame 1
        make new text frame in document 1 with properties {name:"AreaText", contents:TempAttachmentName, position:{(item 1 of bb), ((item 2 of bb) + 40)}}
        set p to 6.1
        try
        make new character style in document 1 with properties {name:"BarCodeBox"}
        end try
        set p to 6.2
        set the size of character style "BarCodeBox" of document 1 to 10
        set p to 6.3
        apply character style character style "BarCodeBox" of document 1 to the text range of text frame "AreaText" of document 1
        set p to 6.4
        set the text font of text range of text frame "AreaText" of document 1 to text font "IDAutomationHC39M"
        # Text Frame 2
        make new text frame in document 1 with properties {name:"AreaTextTwo", contents:my PreserveFileName, position:{(item 1 of bb), ((item 2 of bb) + 21)}}
        set p to 7.1
        try
        make new character style in document 1 with properties {name:"NameBox"}
        end try
        set p to 7.2
        set the size of character style "NameBox" of document 1 to 12
        set p to 7.3
        apply character style character style "NameBox" of document 1 to the text range of text frame "AreaTextTwo" of document 1
        set p to 7.4
        set the text font of text range of text frame "AreaTextTwo" of document 1 to text font "Cochin"
        end if
        set p to 16
        try
        (*set printerName to my theLargePagePrinter as string
        set paperOptions to {class:paper options, name:largePaperSize}
        set jobOptions to {class:job options, designation:all layers} # , print options:printOptions}
        set colorOptions to {class:color management options, profile kind:printer profile, intent:perceptual}
        set flatOpts to {class:flattening options, clip complex regions:true, gradient resolution:360, rasterization resolution:360}
        set printOptions to {class:print options, printer name:printerName, paper settings:paperOptions, flattener settings:flatOpts, job settings:jobOptions, color management settings:colorOptions}
        # If this can't print, the resultant dialog box is unreadable
        print document 1 options printOptions
        on error errmsg number errnum
        tell application "System Events" to display dialog "Error in direct printing illustrator document. " & errmsg & " number " & errnum giving up after 40*)
        activate
        keystroke "p" using command down
        tell current application to delay 0.4
        keystroke (character 1 of (my theLargePagePrinter as text)) as text
        repeat 18 times
        keystroke tab
        end repeat
        keystroke return
        end tell
        tell application "System Events" to display dialog "Error in printing illustrator document. " & errmsg & " number " & errnum giving up after 40
        end try
        tell current application to delay 0.5
        set my diditPrint to false
        tell application "System Events" to display dialog "printIllustrator actual printing " & errmsg & return & errnum & " P = " & p giving up after 40
        end try
        end tell
        end try
      end printIllustrator
