1 Reply Latest reply on Jan 24, 2007 4:18 PM by Fernis
    Web service Invoke using Coldfusion
      I am using the CFInvoke method for calling a .NET web service.
      I am using the following Command for calling the web service.
      webservice=" http://localhost/CES4WS/Indexprogress.asmx?wsdl"
      method = "GetSource"
      strServer ="localhost"
      strInstance = "default"
      strImpersonate ="false"
      strImpersonateUserComingFromServer =""
      strImpersonateUser =""
      strCollection = "demotest1">
      however, when I run this, it is giving me the following error:
      Name: http://localhost/CES4WS/Indexprogress.asmx?wsdl. WSDL: http://localhost/CES4WS/Indexprogress.asmx?wsdl. org.xml.sax.SAXException: Fatal Error: URI=null Line=1: White spaces are required between publicId and systemId. It is recommended that you use a web browser to retrieve and examine the requested WSDL document for correctness. If the requested WSDL document can't be retrieved or it is dynamically generated, it is likely that the target web service has programming errors.
      I did try to run the web service in the IE directly and it is working fine.
