0 Replies Latest reply on Apr 5, 2015 5:25 AM by cathykka
    Export to PDF with MetaData
    cathykka Level 1
      I have a script that exports each individual page to a pdf with each page having it's own metadata.
      It works fine except for on small thing.
      The keyword array looks like this in the final PDF.
      ; "Keyword1, Keyword2, Keyword3
      How do I get rid of the semicolon and quotes?
      Thanks!
      main ();
      function main() {
      var curDoc = app.activeDocument;
      var docPath = app.activeDocument.filePath;
      // Array of paragraph Style names
      var paraStyleNames = ["meta-title", "meta-alt", "meta-subject"]; // insert here your para names !
      var missingParaStyles = [];
      // check, if the styles are valid
      for ( var p = 0; p < paraStyleNames.length; p++ ) {
          var curName = paraStyleNames[p];
          // if the style is missing, push it to the array
          if ( !curDoc.paragraphStyles.itemByName(curName).isValid ) {
              missingParaStyles.push( curName );
      var folderPath = new Folder(docPath + "/" + curDoc.name.replace(/\.indd$/,"") + "-pdf");
          if (!folderPath.exists)
              folderPath.create();
      // loop through all pages
      for ( var i = 0; i < curDoc.pages.length; i++ ) {
          // the current page
          var curPage = curDoc.pages[i];
      // Page number
          var pName = (curPage.name < 10) ? ("0" + curPage.name) : curPage.name;
         // controls the loop
          var controller = true;
        // all paragraphs on the current page
          var allPageParas = curPage.textFrames.everyItem().paragraphs.everyItem().getElements();
          // loop through all paragraphs and check, if one has the para style applied
          for ( var p = 0; p < allPageParas.length; p++ ) {
              if ( !controller ) break;
              // the current para
              var curPara = allPageParas[p];
              // loop through the styles
              for ( var n = 0; n < paraStyleNames.length; n++ ) {
                  if ( curPara.appliedParagraphStyle.name == "meta-title" ) {
                      var docTitle = curPara.contents;
                     } // end if
                  if ( curPara.appliedParagraphStyle.name == "meta-alt" ) {
                      var docAlt = curPara.contents;
                  } // end if
               if ( curPara.appliedParagraphStyle.name == "meta-subject" ) {
                      var docKeywords = curPara.contents;
                      var docDirectory = Array(docKeywords);
                  } // end if
              } // end for paraStyleNames
          } // end for allPageParas
      for (var i = 0; i < docDirectory.length; i++) {
          docDirectory[i] = docDirectory[i].replace(/; /g, "");
          var filePath = folderPath + "/" + curDoc.name.replace(/\.indd$/,"")  + "-" + pName + ".pdf";
          var myFile = File( filePath );
          var pdfPreset = "Labels";
          with (curDoc.metadataPreferences){
          documentTitle = docTitle;
          author = curDoc.name.replace(/\.indd$/,"") ;
          description = docAlt;
          contentCreator = curDoc.name.replace(/\.indd$/,"")  + "-" + pName ;
          keywords =  docDirectory;
      with (app.pdfExportPreferences) {
        pageRange = curPage.name;
        viewPDF = false }
        curDoc.exportFile( ExportFormat.PDF_TYPE, myFile, false, pdfPreset );
        } // end for > main
