0 Replies Latest reply on Jan 18, 2007 1:49 AM by tiagoafpereira
    Possible Bug with Tree
    tiagoafpereira
      The example on tree node removal on http://www.adobe.com/devnet/flex/quickstart/working_with_tree/ seems to have an error.
      If you remove nodes from either Finance or Operations nothing bad occurs but if you delete one of the nodes in Engineering an then close that folder Flash will report an error and the tree will cease to function. On the other hand if you remove one node in Engineering, open or close one of the other folders and then close Engineering the error will not occur.
      I've been using the Tree component on a project and keep getting that same error and so far don't know a way to fix or circumvent it... Help would be great!
      Tiago
