• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Green Screen in Flash Player Still not resolv
Explorer ,
Apr 07, 2015 Apr 07, 2015
Ok, getting really frustrated now. This green screen thing is pissing me right off. I have a barely 2 month old brand new Toshiba Satellite with Windows 8.1. Youtube will sometimes play video and other times not. Facebook simply refuses and all I get is a green screen. When I first got the computer it was fine, so I am thinking that it could be an update that is messed with it. Has anyone actually got a proper reason this is happening and a proper fix? I would love to know because short of doing a factory reset I can't figure it out.
Views
2.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Apr 10, 2015 Apr 10, 2015
Hi Chris,
I appreciate all your help. I have in fact now solved the matter by resetting my laptop. It has restored everything and the video is now working. I still doesn't answer the initial question of what happened but now at least I can view stuff again. Thanks again.
Votes
Translate
Translate
Adobe Employee ,
I'm sorry you are encountering this.  Could you post a copy of your systems dxdiag report?  The instructions below will walk you through the steps for generating this report.
Video playback issues‌
You can either copy/paste the results into a forum reply or you can share this report using these steps:How to share a document
Chris
Votes
Translate
Translate
Report
Report
Explorer ,
Hi Chris, thanks for responding. Here is the picture of the dxdiag box. I hope this helps.dxdiag.jpg
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Thank you.  Can you click the "Save all information..." button at the bottom, then open the file with a text editor (notepad).  I'd like to see what's in the section titled:
Display Devices
Chris
Votes
Translate
Translate
Report
Report
Explorer ,
Hi Chris,
I have attached the TXT file. Let me know if that's helpful. Thanks
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Could you also tell the browser on which this issue occurs?
Votes
Translate
Translate
Report
Report
Explorer ,
IE 11 and Mozilla 🙂
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Unfortunately you can't attach files in the forum, but you can either copy/paste the results into a forum reply or you can share this report using these steps:How to share a document
Chris
Votes
Translate
Translate
Report
Report
Explorer ,
Hey Chris, I have copied the text from the TXT below...
System Information
Time of this report: 4/7/2015, 19:24:08
       Machine name: Alex
   Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_r8.150127-1500)
           Language: English (Regional Setting: English)
System Manufacturer: TOSHIBA
       System Model: Satellite C55D-B
               BIOS: 1.30
          Processor: AMD A8-6410 APU with AMD Radeon R5 Graphics     (4 CPUs), ~2.0GHz
             Memory: 4096MB RAM
Available OS Memory: 3518MB RAM
          Page File: 2785MB used, 4317MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: AMD Radeon(TM) R5 Graphics
       Manufacturer: Advanced Micro Devices, Inc.
          Chip type: AMD Radeon(TM) R4 Graphics (0x9851)
           DAC type: Internal DAC(400MHz)
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_1002&DEV_9851&SUBSYS_F9171179&REV_05
     Display Memory: 2033 MB
   Dedicated Memory: 497 MB
      Shared Memory: 1536 MB
       Current Mode: 1366 x 768 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: unknown
         Monitor Id: SDC4347
        Native Mode: 1366 x 768(p) (59.998Hz)
        Output Type: Internal
        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1267 (English)
     Driver Version: 13.352.1004.1007
        DDI Version: 11.1
     Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
           Miracast: Supported
Hybrid Graphics GPU: Not Supported
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 4/23/2014 13:50:08, 1329864 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B71EE2-DB11-11CF-3A76-1DD9BBC2C535}
          Vendor ID: 0x1002
          Device ID: 0x9851
          SubSys ID: 0xF9171179
        Revision ID: 0x0005
Driver Strong Name: oem1.inf:cb0ae414426c3950:ati2mtag_MullinsPA_Mobile:13.352.1004.1007:pci\ven_1002&dev_9851&subsys_f9171179
     Rank Of Driver: 00DA0001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeVC1_VLD  DXVA2_ModeVC1_IDCT  DXVA2_ModeWMV9_IDCT
   Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Not Supported
            DXVA-HD: Not Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0235&SUBSYS_1179F912&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHD64.sys
         Driver Version: 6.00.0001.7195 (English)
            WHQL Logo'd: Yes
          Date and Size: 3/11/2014 21:00:46, 3891800 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
            Description: Microphone (Realtek High Definition Audio)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
            Description: Stereo Mix (Realtek High Definition Audio)
  Default Sound Capture: No
  Default Voice Capture: No
              Cap Flags: 0x1
Video Capture Devices
Number of Devices: 1
           FriendlyName: TOSHIBA Web Camera - HD
           SymbolicLink: \\?\usb#vid_04f2&pid_b446&mi_00#7&d1ba02b&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
           Manufacturer: Microsoft
             HardwareID: USB\VID_04F2&PID_B446&REV_2708&MI_00,USB\VID_04F2&PID_B446&MI_00
             DriverDesc: USB Video Device
         DriverProvider: Microsoft
          DriverVersion: 6.3.9600.16384
      DriverDateEnglish: 6/21/2006 00:00:00
    DriverDateLocalized: 6/21/2006 12:00:00 AM
                Service: usbvideo
                  Class: Image
          DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
            ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
            ProblemCode: No Problem
  BusReportedDeviceDesc: TOSHIBA Web Camera - HD
                 Parent: USB\VID_04F2&PID_B446\6&2721e99&0&4
      DriverProblemDesc: n/a
           UpperFilters: n/a
           LowerFilters: n/a
                  Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\ACPI,\Driver\usbccgp
      ContainerCategory: Imaging
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: HP Link-5 micro dongle
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x03F0, 0xA407
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Toshiba Hotkey Driver
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x5664, 0x0930
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1022, 0x7808
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 7/24/2014 08:28:38, 419648 bytes
| Driver: usbd.sys, 5/31/2014 03:07:07, 27480 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x0438, 0x7900
| | Matching Device ID: USB\Class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ PC/AT Enhanced PS/2 Keyboard (101/102-Key)
| Matching Device ID: *PNP030B
| Service: i8042prt
| Driver: i8042prt.sys, 8/22/2013 04:39:15, 107520 bytes
| Driver: kbdclass.sys, 8/22/2013 05:43:45, 58208 bytes
+ HID Keyboard Device
| Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| Service: kbdhid
| Driver: kbdhid.sys, 8/22/2013 04:39:13, 32256 bytes
+ HID-compliant mouse
| Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| Service: mouhid
| Driver: mouhid.sys, 8/22/2013 04:39:13, 30208 bytes
| Driver: mouclass.sys, 8/22/2013 05:43:45, 51040 bytes
+ ELAN PS/2_SMBus Port Input Device
| Matching Device ID: *etd0806
| Upper Filters: ETD
| Service: i8042prt
| Driver: ETD.sys, 3/4/2014 14:55:26, 404296 bytes
| Driver: ETDCtrl.exe, 3/4/2014 14:55:20, 3244360 bytes
| Driver: ETDApix.dll, 3/4/2014 14:55:30, 2678088 bytes
| Driver: ETDCmds.dll, 3/4/2014 14:55:30, 2791752 bytes
| Driver: ETDMag.exe, 3/4/2014 14:55:22, 85832 bytes
| Driver: ETDUninst.dll, 3/4/2014 14:55:32, 2230600 bytes
| Driver: ETDUn_inst.exe, 3/4/2014 14:55:24, 2443592 bytes
| Driver: ETDMcpl.dll, 3/4/2014 14:55:32, 9489224 bytes
| Driver: ETDApi.dll, 3/4/2014 14:55:28, 2616480 bytes
| Driver: ETDFavorite.dll, 3/4/2014 14:55:30, 2625696 bytes
| Driver: ETDDeviceInformation.exe, 3/4/2014 14:55:22, 2394440 bytes
| Driver: ETDCtrlHelper.exe, 3/4/2014 14:55:20, 2616136 bytes
| Driver: ETD_DLL.dll, 3/4/2014 14:55:34, 2235720 bytes
| Driver: ETDService.exe, 3/4/2014 14:55:24, 103240 bytes
| Driver: ETDApi32.dll, 3/4/2014 14:55:28, 1665864 bytes
| Driver: ToshibaTp.exe, 3/4/2014 14:55:24, 2142536 bytes
| Driver: ToshibaTp_Win8.exe, 3/4/2014 14:55:26, 2142536 bytes
| Driver: Button_ClickPad.avi, 3/26/2013 16:30:10, 200178 bytes
| Driver: Button_SmartPad.avi, 3/26/2013 16:30:10, 180350 bytes
| Driver: Clicking_1F.avi, 3/26/2013 16:30:10, 99036 bytes
| Driver: Clicking_2F.avi, 3/26/2013 16:30:10, 86856 bytes
| Driver: Continuous_Scroll_H_2F.avi, 3/26/2013 16:30:10, 1307434 bytes
| Driver: Continuous_Scroll_Reverse-H_2F.avi, 3/26/2013 16:30:10, 1277210 bytes
| Driver: Continuous_Scroll_Reverse-V_2F.avi, 3/26/2013 16:30:10, 1407428 bytes
| Driver: Continuous_Scroll_V_2F.avi, 3/26/2013 16:30:10, 1432776 bytes
| Driver: CursorMove_Inertia.avi, 3/26/2013 16:30:10, 176362 bytes
| Driver: DnD01.avi, 3/26/2013 16:30:10, 248448 bytes
| Driver: DnD02.avi, 3/26/2013 16:30:10, 290898 bytes
| Driver: DnD03.avi, 3/26/2013 16:30:10, 260820 bytes
| Driver: Edge_Auto.avi, 3/26/2013 16:30:10, 1496610 bytes
| Driver: Edge_Auto_Reverse.avi, 3/26/2013 16:30:10, 1475512 bytes
| Driver: Edge_Circular.avi, 3/26/2013 16:30:10, 1207060 bytes
| Driver: Edge_Inertial.avi, 3/26/2013 16:30:10, 884262 bytes
| Driver: Edge_Inertial_Reverse.avi, 3/26/2013 16:30:10, 845570 bytes
| Driver: Edge_Reverse_H.avi, 3/26/2013 16:30:10, 389210 bytes
| Driver: Edge_Reverse_V.avi, 3/26/2013 16:30:10, 490268 bytes
| Driver: Edge_Scroll.avi, 3/26/2013 16:30:10, 1433562 bytes
| Driver: Edge_Scroll_Once.avi, 3/26/2013 16:30:10, 805712 bytes
| Driver: Edge_Scroll_Only_V.avi, 3/26/2013 16:30:10, 750096 bytes
| Driver: EdgeSwipe_4F_Left_Win8.avi, 3/26/2013 16:30:10, 1062896 bytes
| Driver: EdgeSwipe_4F_Right_Win8.avi, 3/26/2013 16:30:10, 1070788 bytes
| Driver: EdgeSwipe_4F_Up_Win8.avi, 3/26/2013 16:30:10, 249488 bytes
| Driver: Fastkeys.avi, 3/26/2013 16:30:10, 440404 bytes
| Driver: Palmtracking.avi, 3/26/2013 16:30:10, 443928 bytes
| Driver: Press_3F.avi, 3/26/2013 16:30:10, 196414 bytes
| Driver: Rotation_Circular.avi, 3/26/2013 16:30:10, 391480 bytes
| Driver: Rotation_Twist.avi, 3/26/2013 16:30:10, 324828 bytes
| Driver: Scroll_Auto.avi, 3/26/2013 16:30:10, 1304286 bytes
| Driver: Scroll_Auto_Reverse.avi, 3/26/2013 16:30:10, 1498608 bytes
| Driver: Scroll_Inertial.avi, 3/26/2013 16:30:10, 886626 bytes
| Driver: Scroll_Inertial_Reverse.avi, 3/26/2013 16:30:10, 871278 bytes
| Driver: Scroll_No_FreeScroll.avi, 3/26/2013 16:30:10, 730952 bytes
| Driver: Scroll_Only_V.avi, 3/26/2013 16:30:10, 653734 bytes
| Driver: Scroll_Reverse_H.avi, 3/26/2013 16:30:10, 408386 bytes
| Driver: Scroll_Reverse_V.avi, 3/26/2013 16:30:10, 496570 bytes
| Driver: Sensitivity.avi, 3/26/2013 16:30:10, 246166 bytes
| Driver: SlowMotion.avi, 3/26/2013 16:30:10, 295866 bytes
| Driver: SmartArea.avi, 3/26/2013 16:30:10, 305630 bytes
| Driver: SmartMotion.avi, 3/26/2013 16:30:10, 94820 bytes
| Driver: Swipe_2F_LR_PageUpDown.avi, 3/26/2013 16:30:10, 510374 bytes
| Driver: Swipe_3F_Down_Desktop.avi, 3/26/2013 16:30:10, 223046 bytes
| Driver: Swipe_3F_Down_SwitchWnd.avi, 3/26/2013 16:30:10, 282958 bytes
| Driver: Swipe_3F_LR_PageUpDown.avi, 3/26/2013 16:30:10, 520300 bytes
| Driver: Swipe_3F_Up_Computer.avi, 3/26/2013 16:30:10, 203610 bytes
| Driver: Swipe_3F_Up_SwitchWindow_1F.avi, 3/26/2013 16:30:10, 708276 bytes
| Driver: Swipe_3F_Up_SwitchWindow_3F.avi, 3/26/2013 16:30:10, 1251558 bytes
| Driver: Swipe_3F_Up_TabWindows_1F.avi, 3/26/2013 16:30:10, 226286 bytes
| Driver: Swipe_3F_Up_TabWindows_3F.avi, 3/26/2013 16:30:10, 499014 bytes
| Driver: Swipe_3F_UpDown_SlideShow.avi, 3/26/2013 16:30:10, 832026 bytes
| Driver: Swipe_4F_Down_Desktop.avi, 3/26/2013 16:30:10, 244134 bytes
| Driver: Swipe_4F_Down_SwitchWnd.avi, 3/26/2013 16:30:10, 1065130 bytes
| Driver: Swipe_4F_Up_Desktop.avi, 3/26/2013 16:30:10, 221464 bytes
| Driver: Swipe_4F_Up_SwitchWnd.avi, 12/28/2012 18:27:00, 249488 bytes
| Driver: Swipe_4F_Up_SwitchWnd_Win7.avi, 6/3/2013 10:29:00, 163840 bytes
| Driver: Tapping_1F.avi, 3/26/2013 16:30:10, 111546 bytes
| Driver: Tapping_2F_Middle_Button.avi, 3/26/2013 16:30:10, 289364 bytes
| Driver: Tapping_2F_Popup.avi, 3/26/2013 16:30:10, 228208 bytes
| Driver: Win8EdgeSwipe_Left.avi, 3/26/2013 16:30:10, 720434 bytes
| Driver: Win8EdgeSwipe_Right.avi, 3/26/2013 16:30:10, 147766 bytes
| Driver: Win8EdgeSwipe_Top.avi, 3/26/2013 16:30:10, 267604 bytes
| Driver: Zooming.avi, 3/26/2013 16:30:10, 654070 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
Free Space: 428.4 GB
Total Space: 466.1 GB
File System: NTFS
      Model: TOSHIBA MQ01ABF050
      Drive: D:
      Model: TSSTcorp CDDVDW SU-208FB
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.03.9600.16384 (English), 8/22/2013 01:46:35, 164352 bytes
System Devices
     Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_9840&SUBSYS_F9101179&REV_00\3&11583659&1&09
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.03.9600.17238 (English), 7/24/2014 04:45:39, 76800 bytes
     Name: Realtek PCIE CardReader
Device ID: PCI\VEN_10EC&DEV_5229&SUBSYS_F91B1179&REV_01\4&31D7B68&0&0012
   Driver: C:\Windows\system32\DRIVERS\RtsP2Stor.sys, 6.03.9600.29075 (English), 1/3/2014 16:08:00, 291544 bytes
   Driver: C:\Windows\SysWOW64\RsCRIcon.dll, 1.10.0000.0000 (English), 4/25/2013 18:12:12, 9889352 bytes
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1583&SUBSYS_00000000&REV_00\3&11583659&1&C3
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_780B&SUBSYS_F91B1179&REV_42\3&11583659&1&A0
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1566&SUBSYS_F91B1179&REV_00\3&11583659&1&00
   Driver: n/a
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1022&DEV_1439&SUBSYS_F91B1179&REV_00\3&11583659&1&14
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.03.9600.17238 (English), 7/24/2014 08:28:35, 280384 bytes
Device ID: PCI\VEN_1022&DEV_1439&SUBSYS_F91B1179&REV_00\3&11583659&1&13
Device ID: PCI\VEN_1022&DEV_1439&SUBSYS_F91B1179&REV_00\3&11583659&1&12
     Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1022&DEV_7808&SUBSYS_F91B1179&REV_39\3&11583659&1&98
   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.03.9600.17195 (English), 5/31/2014 03:07:08, 89944 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.03.9600.17195 (English), 5/31/2014 03:07:07, 440664 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.03.9600.17238 (English), 7/24/2014 08:28:38, 419648 bytes
Device ID: PCI\VEN_1022&DEV_7808&SUBSYS_F91B1179&REV_39\3&11583659&1&90
     Name: AMD PSP 1.0 Device
Device ID: PCI\VEN_1022&DEV_1537&SUBSYS_15371022&REV_00\3&11583659&1&40
   Driver: C:\Windows\system32\DRIVERS\amdpsp.sys, 1.18.0000.0000 (English), 2/24/2014 17:45:56, 230088 bytes
   Driver: C:\Windows\system32\DRIVERS\amdkmcsp.sys, 1.18.0000.0000 (English), 2/24/2014 17:45:34, 85704 bytes
   Driver: C:\Windows\system32\amdumcsp.dll, 1.18.0000.0000 (English), 2/24/2014 17:37:10, 77824 bytes
   Driver: C:\Windows\SysWOW64\amdumcsp.dll, 1.18.0000.0000 (English), 2/24/2014 17:36:52, 59392 bytes
   Driver: C:\Windows\system32\t-base_client_api.dll, 1.18.0000.0000 (English), 2/24/2014 17:32:30, 16384 bytes
   Driver: C:\Windows\SysWOW64\t-base_client_api.dll, 1.18.0000.0000 (English), 2/24/2014 17:32:22, 12288 bytes
   Driver: C:\Windows\system32\tbaseregistry64.dll, 1.18.0000.0000 (English), 2/24/2014 17:32:00, 120320 bytes
   Driver: C:\Windows\SysWOW64\tbaseregistry32.dll, 1.18.0000.0000 (English), 2/24/2014 17:31:38, 99840 bytes
   Driver: C:\Windows\SysWOW64\tbaseprovisioning.exe, 1.00.0000.0000 (English), 2/24/2014 17:30:12, 51712 bytes
   Driver: C:\Windows\SysWOW64\tbaseprovisioning.exe.config, 2/24/2014 17:30:12, 2473 bytes
   Driver: C:\Windows\SysWOW64\rootpacommon.dll, 1.12.0000.0000 (English), 2/24/2014 17:30:14, 2952704 bytes
   Driver: C:\Windows\SysWOW64\07010000000000000000000000000000.tlbin, 2/24/2014 17:30:12, 21007 bytes
   Driver: C:\Windows\system32\WdfCoInstaller01011.dll, 1.11.9200.16384 (English), 2/24/2014 17:29:32, 1795952 bytes
   Driver: C:\Windows\system32\pspcoins.dll, 1.00.0005.0009 (English), 2/24/2014 17:29:32, 96256 bytes
     Name: Realtek PCIe FE Family Controller
Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_F91B1179&REV_07\4&2BFE94CA&0&0013
   Driver: C:\Windows\system32\DRIVERS\Rt630x64.sys, 8.24.1218.2013 (English), 1/27/2014 15:13:56, 839896 bytes
   Driver: C:\Windows\system32\RtNicProp64.dll, 1.02.0000.0006 (English), 1/27/2014 15:13:56, 73800 bytes
Device ID: PCI\VEN_1022&DEV_1581&SUBSYS_00000000&REV_00\3&11583659&1&C1
   Driver: n/a
     Name: AMD Radeon(TM) R5 Graphics
Device ID: PCI\VEN_1002&DEV_9851&SUBSYS_F9171179&REV_05\3&11583659&1&08
   Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.1379 (English), 4/23/2014 13:36:58, 13941760 bytes
   Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0024 (English), 4/23/2014 10:28:42, 43520 bytes
   Driver: C:\Windows\system32\atiumd64.dll, 9.14.0010.1017 (English), 4/23/2014 13:48:56, 7896632 bytes
   Driver: C:\Windows\system32\atiumd6a.dll, 8.14.0010.0441 (English), 4/23/2014 13:49:04, 10901184 bytes
   Driver: C:\Windows\system32\atitmm64.dll, 6.14.0011.0025 (English), 4/23/2014 11:08:04, 190976 bytes
   Driver: C:\Windows\system32\atiicdxx.dat, 1/16/2014 17:34:54, 723841 bytes
   Driver: C:\Windows\system32\amdpcom64.dll, 8.14.0010.0023 (English), 4/23/2014 13:50:24, 78432 bytes
   Driver: C:\Windows\system32\atimpc64.dll, 8.14.0010.0023 (English), 4/23/2014 13:50:36, 78432 bytes
   Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1300 (English), 4/23/2014 10:34:02, 1147904 bytes
   Driver: C:\Windows\system32\atiumd6a.cap, 4/23/2014 10:52:36, 3437632 bytes
   Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1002 (English), 4/23/2014 11:10:46, 31232 bytes
   Driver: C:\Windows\system32\atiapfxx.exe, 6.14.0010.1001 (English), 4/23/2014 11:32:14, 368640 bytes
   Driver: C:\Windows\system32\ativvsva.dat, 4/23/2014 10:49:38, 157144 bytes
   Driver: C:\Windows\system32\ativvsvl.dat, 4/23/2014 10:49:38, 204952 bytes
   Driver: C:\Windows\system32\ativvaxy_cik.dat, 4/1/2014 04:47:58, 234804 bytes
   Driver: C:\Windows\system32\ativvaxy_cik_nd.dat, 4/1/2014 04:45:58, 233008 bytes
   Driver: C:\Windows\system32\ativce02.dat, 4/4/2014 07:42:38, 82112 bytes
   Driver: C:\Windows\system32\amdmmcl6.dll, 1.05.0000.0000 (English), 4/23/2014 10:57:08, 44544 bytes
   Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1168 (English), 4/23/2014 11:09:44, 240128 bytes
   Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1168 (English), 4/23/2014 11:10:38, 586240 bytes
   Driver: C:\Windows\system32\atidemgy.dll, 4.05.5225.38126 (English), 4/23/2014 11:10:54, 442368 bytes
   Driver: C:\Windows\system32\atio6axx.dll, 6.14.0010.12804 (English), 4/23/2014 11:32:48, 27186176 bytes
   Driver: C:\Windows\system32\aticalrt64.dll, 6.14.0010.1848 (English), 4/23/2014 11:32:02, 62464 bytes
   Driver: C:\Windows\system32\aticalcl64.dll, 6.14.0010.1848 (English), 4/23/2014 11:31:52, 55808 bytes
   Driver: C:\Windows\system32\aticaldd64.dll, 6.14.0010.1848 (English), 4/23/2014 11:31:34, 15716352 bytes
   Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 4/11/2013 00:34:26, 118784 bytes
   Driver: C:\Windows\system32\atiapfxx.blb, 4/23/2014 11:32:44, 577232 bytes
   Driver: C:\Windows\system32\amdmiracast.dll, 4/23/2014 11:39:34, 415232 bytes
   Driver: C:\Windows\system32\amdhdl64.dll, 4/23/2014 10:23:46, 134144 bytes
   Driver: C:\Windows\system32\atidxx64.dll, 8.17.0010.0539 (English), 4/23/2014 13:49:54, 10177624 bytes
   Driver: C:\Windows\SysWOW64\atiumdag.dll, 9.14.0010.1017 (English), 4/23/2014 13:49:16, 6715752 bytes
   Driver: C:\Windows\SysWOW64\atiumdva.dll, 8.14.0010.0441 (English), 4/23/2014 13:49:30, 10146664 bytes
   Driver: C:\Windows\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 4/23/2014 13:50:22, 71704 bytes
   Driver: C:\Windows\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 4/23/2014 13:50:34, 71704 bytes
   Driver: C:\Windows\SysWOW64\atiadlxy.dll, 6.14.0010.1300 (English), 4/23/2014 10:33:48, 826880 bytes
   Driver: C:\Windows\SysWOW64\atiumdva.cap, 4/23/2014 10:40:48, 3471376 bytes
   Driver: C:\Windows\SysWOW64\ativvsva.dat, 4/23/2014 10:49:38, 157144 bytes
   Driver: C:\Windows\SysWOW64\ativvsvl.dat, 4/23/2014 10:49:38, 204952 bytes
   Driver: C:\Windows\SysWOW64\amdmmcl.dll, 1.05.0000.0000 (English), 4/23/2014 10:57:02, 35840 bytes
   Driver: C:\Windows\SysWOW64\atioglxx.dll, 6.14.0010.12804 (English), 4/23/2014 11:12:18, 22860800 bytes
   Driver: C:\Windows\SysWOW64\atidxx32.dll, 8.17.0010.0539 (English), 4/23/2014 13:49:46, 8764952 bytes
   Driver: C:\Windows\SysWOW64\aticalrt.dll, 6.14.0010.1848 (English), 4/23/2014 11:31:58, 52224 bytes
   Driver: C:\Windows\SysWOW64\aticalcl.dll, 6.14.0010.1848 (English), 4/23/2014 11:31:50, 49152 bytes
   Driver: C:\Windows\SysWOW64\aticaldd.dll, 6.14.0010.1848 (English), 4/23/2014 11:28:10, 14302208 bytes
   Driver: C:\Windows\SysWOW64\atiapfxx.blb, 4/23/2014 11:32:44, 577232 bytes
   Driver: C:\Windows\SysWOW64\amdhdl32.dll, 4/23/2014 10:23:44, 123392 bytes
   Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 4/11/2013 00:34:26, 51200 bytes
   Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 4/11/2013 00:34:26, 332800 bytes
   Driver: C:\Windows\system32\amdave64.dll, 5.11.0006.0000 (English), 4/23/2014 10:32:02, 95744 bytes
   Driver: C:\Windows\SysWOW64\amdave32.dll, 5.11.0006.0000 (English), 4/23/2014 10:31:56, 90112 bytes
   Driver: C:\Windows\system32\atisamu64.dll, 7.01.0000.0001 (English), 4/23/2014 10:31:44, 89088 bytes
   Driver: C:\Windows\system32\amdhcp64.dll, 1.00.0000.0001 (English), 4/23/2014 13:51:12, 127872 bytes
   Driver: C:\Windows\system32\kapp_ci.sbin, 3/25/2014 04:12:46, 42544 bytes
   Driver: C:\Windows\system32\kapp_si.sbin, 3/27/2014 00:10:48, 38544 bytes
   Driver: C:\Windows\system32\samu_krnl_ci.sbin, 12/12/2013 22:53:56, 138832 bytes
   Driver: C:\Windows\system32\samu_krnl_isv_ci.sbin, 12/12/2013 22:53:56, 138832 bytes
   Driver: C:\Windows\SysWOW64\atisamu32.dll, 7.01.0000.0001 (English), 4/23/2014 10:31:38, 80896 bytes
   Driver: C:\Windows\SysWOW64\amdhcp32.dll, 1.00.0000.0001 (English), 4/23/2014 13:51:10, 117560 bytes
   Driver: C:\Windows\system32\DRIVERS\atikmpag.sys, 8.14.0001.6367 (English), 4/23/2014 10:32:36, 628224 bytes
   Driver: C:\Windows\system32\atipblag.dat, 9/13/2011 07:06:18, 3917 bytes
   Driver: C:\Windows\system32\atiu9p64.dll, 8.14.0001.6367 (English), 4/23/2014 13:50:14, 116024 bytes
   Driver: C:\Windows\system32\atiuxp64.dll, 8.14.0001.6367 (English), 4/23/2014 13:50:18, 143304 bytes
   Driver: C:\Windows\system32\atig6txx.dll, 8.14.0001.6367 (English), 4/23/2014 10:33:24, 146432 bytes
   Driver: C:\Windows\system32\atiglpxx.dll, 8.14.0001.6367 (English), 4/23/2014 10:33:28, 69632 bytes
   Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1267 (English), 4/23/2014 13:50:08, 1329864 bytes
   Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1267 (English), 4/23/2014 13:50:02, 1107384 bytes
   Driver: C:\Windows\system32\OpenCL.dll, 2.00.0000.0000 (English), 4/23/2014 11:38:10, 65024 bytes
   Driver: C:\Windows\system32\amdocl64.dll, 10.00.1411.0004 (English), 4/23/2014 11:43:00, 28427264 bytes
   Driver: C:\Windows\system32\amdocl_as64.exe, 4/23/2014 11:43:26, 1187342 bytes
   Driver: C:\Windows\system32\amdocl_ld64.exe, 4/23/2014 11:43:26, 1061902 bytes
   Driver: C:\Windows\system32\OpenVideo64.dll, 10.00.1411.0004 (English), 4/23/2014 11:43:22, 98816 bytes
   Driver: C:\Windows\system32\OVDecode64.dll, 10.00.1411.0004 (English), 4/23/2014 11:43:10, 86528 bytes
   Driver: C:\Windows\system32\clinfo.exe, 4/23/2014 11:43:38, 230912 bytes
   Driver: C:\Windows\SysWOW64\OpenCL.dll, 2.00.0000.0000 (English), 4/23/2014 11:38:06, 58880 bytes
   Driver: C:\Windows\SysWOW64\amdocl.dll, 10.00.1411.0004 (English), 4/23/2014 11:40:28, 23905280 bytes
   Driver: C:\Windows\SysWOW64\amdocl_as32.exe, 4/23/2014 11:43:24, 995342 bytes
   Driver: C:\Windows\SysWOW64\amdocl_ld32.exe, 4/23/2014 11:43:24, 798734 bytes
   Driver: C:\Windows\SysWOW64\OpenVideo.dll, 10.00.1411.0004 (English), 4/23/2014 11:43:16, 83456 bytes
   Driver: C:\Windows\SysWOW64\OVDecode.dll, 10.00.1411.0004 (English), 4/23/2014 11:43:06, 73216 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.sbz, 8.14.0001.6020 (English), 12/14/2013 05:00:58, 36608 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.ibz, 1/7/2014 04:12:24, 1981 bytes
   Driver: C:\Program Files\AMD\amdkmpfd\amdkmpfd.cbz, 1/7/2014 16:00:42, 9946 bytes
   Driver: C:\Windows\system32\atig6pxx.dll, 8.14.0001.6367 (English), 4/23/2014 10:33:32, 75264 bytes
   Driver: C:\Windows\SysWOW64\atipblag.dat, 9/13/2011 07:06:18, 3917 bytes
   Driver: C:\Windows\SysWOW64\atiu9pag.dll, 8.14.0001.6367 (English), 4/23/2014 13:50:12, 99008 bytes
   Driver: C:\Windows\SysWOW64\atiuxpag.dll, 8.14.0001.6367 (English), 4/23/2014 13:50:18, 126336 bytes
   Driver: C:\Windows\SysWOW64\atigktxx.dll, 8.14.0001.6367 (English), 4/23/2014 10:33:00, 133120 bytes
   Driver: C:\Windows\SysWOW64\atiglpxx.dll, 8.14.0001.6367 (English), 4/23/2014 10:33:28, 69632 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDh264Enc32.dll, 1.00.0000.0001 (English), 4/23/2014 11:38:28, 258048 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDh264Enc64.dll, 1.00.0000.0001 (English), 4/23/2014 11:38:50, 290304 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDhwDecoder_32.dll, 1.00.0000.0001 (English), 4/23/2014 11:41:42, 196608 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\AMDhwDecoder_64.dll, 1.00.0000.0001 (English), 4/23/2014 11:42:20, 232960 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\amf-mft-mjpeg-decoder32.dll, 1.00.0000.0002 (English), 4/23/2014 11:38:16, 2150400 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\amf-mft-mjpeg-decoder64.dll, 1.00.0000.0002 (English), 4/23/2014 11:39:00, 2192384 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\mcl32.dll, 1.04.0000.0000 (English), 9/23/2013 21:49:02, 49152 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\mcl64.dll, 1.04.0000.0000 (English), 9/23/2013 21:49:02, 64512 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\amf-wic-jpeg-decoder32.dll, 1.01.0000.0000 (English), 4/23/2014 11:39:58, 407552 bytes
   Driver: C:\Program Files\Common Files\ATI Technologies\Multimedia\amf-wic-jpeg-decoder64.dll, 1.01.0000.0000 (English), 4/23/2014 11:40:16, 415232 bytes
   Driver: C:\Windows\system32\coinst_13.352.dll, 1.00.0005.0009 (English), 4/23/2014 10:40:02, 808960 bytes
     Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1022&DEV_7801&SUBSYS_F91B1179&REV_40\3&11583659&1&88
   Driver: C:\Windows\system32\DRIVERS\storahci.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:31, 107872 bytes
Device ID: PCI\VEN_1022&DEV_1584&SUBSYS_00000000&REV_00\3&11583659&1&C4
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_156B&SUBSYS_00000000&REV_00\3&11583659&1&10
   Driver: n/a
     Name: LPC Interface Controller
Device ID: PCI\VEN_1022&DEV_780E&SUBSYS_F91B1179&REV_11\3&11583659&1&A3
   Driver: C:\Windows\system32\DRIVERS\LPCFilter.sys, 1.00.0064.0007 (English), 8/1/2013 15:34:10, 35672 bytes
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.03.9600.16384 (English), 8/22/2013 05:43:49, 17248 bytes
     Name: Qualcomm Atheros AR956x Wireless Network Adapter
Device ID: PCI\VEN_168C&DEV_0036&SUBSYS_28A21B9A&REV_01\4&1944E425&0&0014
   Driver: C:\Windows\system32\DRIVERS\athwbx.sys, 10.00.0000.0285 (English), 2/14/2014 04:35:20, 3888640 bytes
   Driver: C:\Windows\system32\drivers\vwifibus.sys, 6.03.9600.16384 (English), 8/22/2013 04:39:00, 24576 bytes
Device ID: PCI\VEN_1022&DEV_1582&SUBSYS_00000000&REV_00\3&11583659&1&C2
   Driver: n/a
     Name: AMD USB 3.0 eXtensible Host Controller - 0100 (Microsoft)
Device ID: PCI\VEN_1022&DEV_7814&SUBSYS_F91B1179&REV_11\3&11583659&1&80
   Driver: C:\Windows\system32\DRIVERS\UCX01000.SYS, 6.03.9600.17031 (English), 3/18/2014 02:54:38, 189784 bytes
   Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 6.03.9600.17031 (English), 3/18/2014 02:54:38, 325464 bytes
Device ID: PCI\VEN_1022&DEV_780D&SUBSYS_F91B1179&REV_02\3&11583659&1&A2
Device ID: PCI\VEN_1022&DEV_1585&SUBSYS_00000000&REV_00\3&11583659&1&C5
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1580&SUBSYS_00000000&REV_00\3&11583659&1&C0
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.03.9600.16384
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.03.9600.16384
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.03.9600.16384
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.03.9600.16384
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.03.9600.16384
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.03.9600.16384
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.03.9600.17238
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.03.9600.16384
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.03.9600.16384
DV Muxer,0x00400000,0,0,qdv.dll,6.06.9600.16384
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.9600.16384
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.9600.16384
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.9600.16384
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.9600.16384
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.9600.16384
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9600.16476
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.9600.16384
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.9600.16384
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.9600.16384
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.9600.16384
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.9600.16384
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.9600.16384
ATI MPEG File Writer,0x00200000,1,0,atimpenc64.dll,13.30.0000.40422
AMD Video Decoder,0x00200000,1,2,atimpenc64.dll,13.30.0000.40422
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.9600.16384
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.9600.16384
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.9600.16384
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.9600.16384
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.9600.16384
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.9600.16384
DV Splitter,0x00600000,1,2,qdv.dll,6.06.9600.16384
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.9600.16384
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.9600.16384
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc64.dll,13.30.0000.40422
AMD MJPEG Decoder,0x00200000,1,1,atimpenc64.dll,13.30.0000.40422
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.9600.16384
Video Renderer,0x00800001,1,0,quartz.dll,6.06.9600.16384
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.9600.16384
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.9600.16384
Video Renderer,0x00400000,1,0,quartz.dll,6.06.9600.16384
AMD Video Encoder,0x00200000,1,1,atimpenc64.dll,13.30.0000.40422
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc64.dll,13.30.0000.40422
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.9600.16384
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.9600.16384
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.03.9600.16384
File writer,0x00200000,1,0,qcap.dll,6.06.9600.16384
AMD Video Scaler Filter,0x00200000,1,1,atimpenc64.dll,13.30.0000.40422
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.9600.16384
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.9600.16384
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.9600.16384
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.9600.16384
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.9600.16384
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.9600.17200
Null Renderer,0x00200000,1,0,qedit.dll,6.06.9600.17200
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.9600.16384
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.03.9600.16384
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.9600.16384
Smart Tee,0x00200000,1,2,qcap.dll,6.06.9600.16384
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.9600.16384
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.9600.16384
Wave Parser,0x00400000,1,1,quartz.dll,6.06.9600.16384
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.9600.16384
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.9600.16384
File stream renderer,0x00400000,1,1,quartz.dll,6.06.9600.16384
AMD Video Rotation Filter,0x00200000,1,1,atimpenc64.dll,13.30.0000.40422
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.9477.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.9600.16384
AVI Mux,0x00200000,1,0,qcap.dll,6.06.9600.16384
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.9600.16384
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.9600.16384
File Source (URL),0x00400000,0,1,quartz.dll,6.06.9600.16384
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.9600.16384
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.03.9600.16384
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.9600.16384
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.9600.16384
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.03.9600.16384
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.03.9600.16384
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.03.9600.16384
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.03.9600.16384
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.9600.16384
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.9600.16384
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.03.9600.16384
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.03.9600.16384
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.9600.16384
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.9600.16384
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.9600.16384
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.9600.16384
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.9600.16384
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.9600.16384
Audio Capture Sources:
Microphone (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,6.06.9600.16384
Stereo Mix (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,6.06.9600.16384
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.9600.16384
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.9600.16384
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.9600.16384
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.9600.16384
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.9600.16384
WDM Streaming Capture Devices:
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.03.9600.16384
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.03.9600.16384
TOSHIBA Web Camera - HD,0x00200000,1,1,ksproxy.ax,6.03.9600.16384
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.03.9600.16384
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.16384
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.16384
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.16384
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.16384
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.9600.16384
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.9600.16384
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.9600.16384
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.9600.16384
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.9600.16384
PTFilter,0x00200000,0,0,EncDec.dll,6.06.9600.16384
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.9600.16384
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.9600.16384
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.9600.16384
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.9600.16384
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.9600.16384
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  AMD D3D11 Hardware MFT Playback Decoder, {17796AEB-0F66-4663-B8FB-99CBEE0224CE}, 0x4, 8, AMDhwDecoder_64.dll, 1.00.0000.0001
  AMD MFT MJPEG Decoder, {687CBC51-25DA-4FFC-A678-1E64943285A7}, 0x4, 8, amf-mft-mjpeg-decoder64.dll, 1.00.0000.0002
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 12.00.9600.16476
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 6.03.9600.16384
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 6.03.9600.16384
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 12.00.9600.16476
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 6.03.9600.16384
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 6.03.9600.17238
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 6.03.9600.16384
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 6.03.9600.16384
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 6.03.9600.16384
Video Encoders:
  AMD H.264 Hardware MFT Encoder, {ADC9BC80-0F41-46C6-AB75-D693D793597D}, 0x4, 8, AMDh264Enc64.dll, 1.00.0000.0001
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 6.03.9600.16384
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 6.03.9600.16384
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 6.03.9600.16384
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 12.00.9600.16384
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 6.03.9600.16384
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 6.03.9600.16384
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 6.03.9600.17090
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 6.03.9600.16384
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 6.03.9600.16384
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 12.00.9600.17031
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, MSAudDecMFT.dll, 6.03.9600.16384
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 6.03.9600.16384
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 6.03.9600.16384
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 12.00.9600.17238
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 12.00.9600.17238
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 6.03.9600.16384
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 6.03.9600.16384
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 6.03.9600.16384
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 12.00.9600.17238
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 12.00.9600.17238
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 6.03.9600.16384
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 12.00.9600.17238
Audio Encoders:
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 12.00.9600.17238
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 6.03.9600.16384
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 12.00.9600.16384
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 6.03.9600.16384
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 6.03.9600.16384
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 6.03.9600.16384
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 6.03.9600.16384
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 6.03.9600.16384
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 12.00.9600.17090
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 12.00.9600.16476
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket -853212865, type 5
Event Name: WPNConnectionFailure
Response: Not available
Cab Id: 0
Problem signature:
P1: Data Connect
P2: 880403fa
P3: WNP
P4: Unknown
P5: Unknown
P6: Unknown
P7: 2
P8: 244
P9:
P10:
+++ WER1 +++:
Fault bucket -857616767, type 5
Cab Id: 0
Problem signature:
P1: Data Reconnect
P2: 880403fa
P3: WNP
P4: Unknown
P5: Unknown
P6: Unknown
P7: 2
P8: 244
P9:
P10:
+++ WER2 +++:
Cab Id: 0
Problem signature:
P1: Data Connect
P2: 880403fa
P3: WNP
P4: Unknown
P5: Unknown
P6: Unknown
P7: 2
P8: 244
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P1: Data Connect
P2: 880403fa
P3: WNP
P4: Unknown
P5: Unknown
P6: Unknown
P7: 2
P8: 244
P9:
P10:
+++ WER4 +++:
Fault bucket 98941669696, type 5
Event Name: MoAppHangXProc
Cab Id: 99003006365
Problem signature:
P1: windows.immersivecontrolpanel_6.2.0.0_neutral_neutral_cw5n1h2txyewy
P2: praid:microsoft.windows.immersivecontrolpanel
P3: 6.3.9600.17324
P4: 53f834a5
P5: 2fc0
P6: 2097280
P7: UNKNOWN
P8: svchost.exe
P9: 0.0.0.0
P10:
+++ WER5 +++:
Fault bucket , type 0
Event Name: APPCRASH
Cab Id: 0
Problem signature:
P1: svchost.exe
P2: 6.3.9600.16384
P3: 5215dfe3
P4: ntdll.dll
P5: 6.3.9600.17668
P6: 54c850f5
P7: c0000005
P8: 0000000000037e69
P9:
P10:
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: svchost.exe
P2: 6.3.9600.16384
P3: 5215dfe3
P4: ntdll.dll
P5: 6.3.9600.17668
P6: 54c850f5
P7: c0000005
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: Data Reconnect
P2: 880403fa
P3: WNP
P4: Unknown
P5: Unknown
P6: Unknown
P7: 2
P8: 244
P9:
P10:
+++ WER8 +++:
Cab Id: 0
Problem signature:
P1: Data Reconnect
P2: 880403fa
P3: WNP
P4: Unknown
P5: Unknown
P6: Unknown
P7: 2
P8: 244
P9:
P10:
+++ WER9 +++:
Cab Id: 0
Problem signature:
P1: Data Connect
P2: 880403fa
P3: WNP
P4: Unknown
P5: Unknown
P6: Unknown
P7: 2
P8: 244
P9:
P10:
Votes
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Apr 08, 2015 Apr 08, 2015
Thank you.  It looks like the video driver is out of date.  Could you try updating to the latest release (dated 12/14) and see if that makes a difference?
Mobile ATI Driver‌
Chris
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks Chris,
Can you tell me which part of the information gave the clue that the driver needs updating? (maybe copy and paste that section in another window?) I would be curious because I checked the control panel and device driver and it looks, at first glance, like there's no video driver at all. The video and sound drivers only show audio. Can you point out the section for me, please?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
You'll want to look in the following section:
Display Devices
          Card name: AMD Radeon(TM) R5 Graphics
      Manufacturer: Advanced Micro Devices, Inc.
          Chip type: AMD Radeon(TM) R4 Graphics (0x9851)
          DAC type: Internal DAC(400MHz)
        Device Type: Full Device
        Device Key: Enum\PCI\VEN_1002&DEV_9851&SUBSYS_F9171179&REV_05
    Display Memory: 2033 MB
  Dedicated Memory: 497 MB
      Shared Memory: 1536 MB
      Current Mode: 1366 x 768 (32 bit) (60Hz)
      Monitor Name: Generic PnP Monitor
      Monitor Model: unknown
        Monitor Id: SDC4347
        Native Mode: 1366 x 768(p) (59.998Hz)
        Output Type: Internal
        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.d ll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1267 (English)
    Driver Version: 13.352.1004.1007
        DDI Version: 11.1
    Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
      Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
          Miracast: Supported
Hybrid Graphics GPU: Not Supported
    Power P-states: Not Supported
  Driver Attributes: Final Retail
  Driver Date/Size: 4/23/2014 13:50:08, 1329864 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
Votes
Translate
Translate
Report
Report
Explorer ,
Hmm, that makes sense. Ok, I am downloading the AMD driver right now from the link you provided. It's going to take about an hour so I will let you know what happens.
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 09, 2015 Apr 09, 2015
Hi Chris,
Still having issues. Do you know how long this is supposed to take to download and install? I downloaded it yesterday and it took over an hour. When I try to install, it zips through the first two processes but when it comes to installation it seems to hang up and just not do anything? How long should the process take to complete? Suggestions would be good because I still can't watch a video.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
It shouldn't take more than a few minutes total.  I'm not sure why the driver installation is stalling out, AMD or your computer manufacturer might be able to give clues here.
Let's try a different tack and see if disabling hardware acceleration in Flash Player makes a difference for the green screen.
How do I disable or enable hardware acceleration?
Votes
Translate
Translate
Report
Report
Explorer ,
That's the problem I have been having. When I go into my settings on Flash Player and I don't have the hardware acceleration option. That's why I suspect that my video driver is no longer present on the machine. When I right click on flash player the far left screen style button is not there. I open with a privacy settings screen. It's just not there and I have no clue why it disappeared.flash.jpg
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Apr 10, 2015 Apr 10, 2015
Are you using Internet Explorer?  If so, take a look at the bottom of that FAQ and there's another link to a Microsoft document that walks you through turning "software rendering" on.  It's the same difference and would be good to know if that helps.  If it doesn't we should just revert it back to software rendering off.
Votes
Translate
Translate
Report
Report
Explorer ,
Hi Chris,
I appreciate all your help. I have in fact now solved the matter by resetting my laptop. It has restored everything and the video is now working. I still doesn't answer the initial question of what happened but now at least I can view stuff again. Thanks again.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
That's good to hear.  After restoring, did you go through and do any windows updates?  If not, I would be curious to know if this returns once those updates are applied.
Votes
Translate
Translate
Report
Report
Explorer ,
Windows did everything but the driver that was installed has remained the same. Here is a snippet of the TXT for the dxdiag as it is now.
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
        DDI Version: 11.1
           Miracast: Supported
        WHQL Logo'd: Yes
    WHQL Date Stamp:
I think it just installed it back properly because the control for the driver was missing.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Well that's great to know, I'm very glad to hear you have it all sorted!
Votes
Translate
Translate
Report
Report
New Here ,
Apr 11, 2015 Apr 11, 2015
I'm having the exact same problem with my new laptop...but I can't fix it! Flash player is enabled in the 'manage add-ons' and I have disabled 'ActiveX'...I've tried posting a question on here but it won't let me?!
Votes
Translate
Translate
Report
Report
Explorer ,
Hi Siobhan
What laptop have you got, how old is it and what is it running?
Votes
Translate
Translate
Report
Report
New Here ,
Apr 17, 2015 Apr 17, 2015
Hi, Its a HP pavilion I bought it about 2 months ago. It is a windows 8.1
Votes
Translate
Translate
Report
Report
LATEST
Hi Siobhan,
Please try updating your graphics driver. you can even try disabling hardware acceleration by right clicking on website content and unchecking the hardware acceleration check box.
Votes
Translate
Translate
Report
Report
