I have two CF10 instances on a server. After applying hotfix 15 the second instance will not start. There are 4 sites, 3 in one instance and the fourth in another. I configured 3 connectors via the wsconfig tool in cfusion and the fourth via wsconfig tool from the second instance.
A command line start shows this error...any ideas?
SEVERE: Failed to initialize connector [Connector[AJP/1.3-8013]]
org.apache.catalina.LifecycleException: Failed to initialize component [Connecto
r[AJP/1.3-8013]]
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:106)
at org.apache.catalina.core.StandardService.initInternal(StandardService
.java:559)
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102)
at org.apache.catalina.core.StandardServer.initInternal(StandardServer.j
ava:813)
at com.adobe.coldfusion.launcher.Launcher.run(Launcher.java:293)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.adobe.coldfusion.bootstrap.Bootstrap.init(Bootstrap.java:86)
at com.adobe.coldfusion.bootstrap.Bootstrap.main(Bootstrap.java:161)
Caused by: java.lang.NoSuchMethodError: org.apache.coyote.ProtocolHandler.isAprR
equired()Z
at org.apache.catalina.connector.Connector.initInternal(Connector.java:9
70)
... 11 more
Apr 07, 2015 1:27:13 PM org.apache.catalina.core.StandardService initInternal
worker.properties file
worker.list=internal_prod
worker.cfusion.type=ajp13
worker.cfusion.host=localhost
worker.cfusion.port=8013
worker.cfusion.max_reuse_connections=250
Somehow the second instance was hosed so I created a new one. I was able to create the connector on the new instance no problem.
