Hi All,
So this is about the resolution of the webcam and it "auto" zooming when the webcam window is reduced.
ie.. I have a 480p camera and when the video window is large (approx a quarter of screen real-estate) all is fine. As i reduce the window or ad more cams from other presenters the image is cropped to just the centre 280p . rather than just reducing the window size it reduces the images size as well. So a head shot turns into an extreme close up!
This issue does not happen on a mac.
Both are using the adobeconnectaddin and are up to date with flash etc.
Any ideas?
I am having the same issue. When I am acting as the presenter in Adobe Connect and a student joins my class, my webcam suddenly zooms in on my face. This actually happens on any Adobe Connect session whether I am presenter or joiner, and it only happens once others start to join. I am using Windows 10, with a built-in webcam on a Dell Inspiron 5368 (5000 series brand new) and usually use Google Chrome as my browser. It doesn't happen with any other webcam applications (I've used Google Hangouts, Skype, and other software that requires the webcam and allows others to join).
This seriously affects my ability to teach using this software, and the course coordinator who decides what software to use is aware of this issue as well. Can someone please look at this???
The solution to this was in controlling the screen real estate and camera resolution.
You will notice if you adjust your cam window size that at a point the image will jump to full frame. as you make the window smaller it will crop to the center of the image.
The only work around is to use a plugin to reduce the resolution of the camera to 520 as a 1080 image will always crop on a smaller window.
I have this problem and in need of a resulution (pardan the pun). Where is this plug-in if that is the only solution? I have a Surface 3.
Mike
Were you able to find a solution for this?
I would like to also add my voice to those saying that this is still a problem 4 years later.
Yes I am having this problem now in October 2020
same in febuary 2021
Adobe why cant you just fix this. Do you really think presenters are going to download a 3rd party app just to fix Adobe Connect's issue. Fix this damn it. It is so frustrating to deal with your glitches
Reach out to Adobe and tell them: https://helpx.adobe.com/adobe-connect/connect-support.html
Same issue here, the camera is cropping the image instead of resiszing. No matter the browser, everything (Windows, divers, etc.) is up to date and so forth.
I've tried reaching out to Adobe support, I've spent 3 hours in the chat with a tech asking me unrelated questions (like "have you tried rebooting the computer") and never proposing solutions. It's ponitless to try to get a hold of support. My suggestion: use another platform than Adobe Connect if you can.
Over 5 years this has been an issue. FIVE YEARS! Adobe is the WORST.
I know! I have the same problem.
What 3rd Party app is used to reduce the camera? My daughter's online school uses Adobe Connect for classes and she hates to be on camera because of this zooming issue. We have been struggling since August. If there are a few people on the call, her camera behaves. If more join the class, it zooms in for an extreme close up. 😞
The default on the Camera app for her laptop was 720p 16:9. I changed it to 480 4:3 and 360 16:9. All had the Zooming issue.
This is a terrible issue and made even more horrible by the fact that it hasn't been fixed in over 4 years!
Hi
I have been traumatized by this problem for well over an year with adobe connect on my surface pro 4. I even bought a USB webcam to use, just so that I could overcome this horrible blow on my face zoom up. Nothing seemed to correct his problem. However, I am happy to tell you that I have found a solution that worked for me.
It worked for me. The way this happens is that OBS takes the webcam feed and converts it into a virtual webcam which surprisingly does not zoom in in adobe connect.
Worked for me.. hope this helps....
Just to add: setting the OBS Virtual CAM video to a 640X480 resolution helps to eliminate the zooming.
Clever. Thanks for sharing!
I'm very surprised that this issue is not fixed in the application itself as a patch, 7 years later!
I have been using ManyCam and it gives me a zoom option. It is not perfect, but it does help.
How did you do this? I need help
I looked up BethConley's suggestion of ManyCam.
I downloaded the free version. I followed a guide to set it up and I made sure to click on all the smallest resolution options. When the Adobe Connect goes to the zoomed in setting, her resolution is more square than rectangular, but it keeps her face a normal size instead of a zoom in on her face.
https://manycam.com/applications/?view=adobe_connect
I hope this helps, and thanks again, BethConley!
my suggestion for you is to check the settings in Adobe Connect and make sure that your webcam is properly configured. Also, check to see if there are any updates available for Adobe Connect on your PC. If those steps don't work, try updating the webcam driver on your PC. Hopefully, these tips will help you resolve the issue and allow you to have smooth remote meetings in the future. Best of luck! jio speed test
