5 Replies Latest reply on Jan 18, 2007 12:10 PM by kglad
    Variables newbie question
    Level 7
      Newbie Question:
      Is a function considered a variable?
      I have the following identical functions "function firstImage()" in two
      swfs. The 2nd swf is loaded from the 1st swf.
      How can all the variables within the 2nd function = the variable values
      within the 1st function?
      Can I replace the function in the 2nd swf something like this or am I
      totally off on this?
      function firstImage() = _parent.function firstImage();
      function firstImage() {
      if (loaded == filesize) {
      picture._alpha = 0;
      picture.loadMovie(image[0], 1);
      desc_txt.htmlText = description[0];
      notes_txt.htmlText = notes[p];
      Pic1Desc_txt.htmlText = Pic1Desc[p];
      detailimage1.loadMovie(picture1[p], 1);
      picture_num();
      Thank you
        • 1. Re: Variables newbie question
          Level 7
          "Joe T" <mail@tese.com> wrote in message
          news:eom3se$oc8$1@forums.macromedia.com...
          > Newbie Question:
          > picture._alpha = 0;
          > picture_num();
          > Thank you
          There are a few things you can do here. It kind of depends on what scope
          you want the function to run under.
          For example:
          this.firstImage = mx.utils.Delegate.create(this._parent, firstImage);
          Will work, running the parent's firstImage function in the scope of this
          (meaning the child or imported swf).
          Or you can do this:
          this.firstImage = this._parent.firstImage;
          This will work too, however the scope of the function is now based on the
          _parent clip, not the loaded clip.
          HTH
          • 2. Re: Variables newbie question
            make the variables global by prefixing them with _global. each time they are assigned a value.
            • 3. Re: Variables newbie question
              and yes, you can reference a function in one movieclip from any other movieclip by using the correct path to that function.
              but the code you showed wouldn't work.
              • 4. Re: Variables newbie question
                Level 7
                Thank you for your responses.
                I made the variables global and is working fine now.
                "kglad" <webforumsuser@macromedia.com> wrote in message
                news:eom62i$qk3$1@forums.macromedia.com...
                • 5. Re: Variables newbie question
                  you're welcome.
