3 Replies Latest reply on Apr 9, 2015 7:38 AM by c.pfaffenbichler
    get tiff compression type
    suresh0208 Level 1
      I want to a series of  TIFF files compression [LZW or NONE] in a folder.
      Can anyone help me in this . . .
      The Script goes here:
      #target photoshop
      var myInputFolder = Folder.selectDialog ("INPUT");
      if(myInputFolder!=null){
          var myFiles = myInputFolder.getFiles(/\.(tif)$/i);
          for(var fileIndex=0;fileIndex<myFiles.length;fileIndex++)
              var currentFile = myFiles[fileIndex];
              if(currentFile instanceof File)
                      if(currentFile.hidden) continue;
                          var doc = app.open(currentFile);
                          if(doc.encoding != TIFFEncoding.TIFFLZW)
                              //Here I want to write code for checking compression of TIFF.
                               alert("Compression should be NONE")
      Thanks In Advance,
      Suresh.N.
        • 1. Re: get tiff compression type
          Philip Cord Level 4
          Here is a function to get the compression.
          #target photoshop;
          var file = File("/j/testing/tifs/11.tif");
          alert(getTifCompession(file));
          function getTifCompession(file){
          if (ExternalObject.AdobeXMPScript == undefined) ExternalObject.AdobeXMPScript = new ExternalObject('lib:AdobeXMPScript');
          var xmpf = new XMPFile(file.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_READ);
          var xmp = xmpf.getXMP();
           try{
          var comp = xmp.getProperty( XMPConst.NS_TIFF, "Compression" ).toString();
          var result = '';
          switch( Number(comp) ){
               case 1:  result = "none"; break;
               case 5:  result = "lzw";  break;
               case 7:  result = "jpg";  break;
               case 8:  result =  "zip";  break;
               default: result =  "unknown";
          return result;
          }catch(e){return undefined;}
          • 2. Re: get tiff compression type
            suresh0208 Level 1
            Thanks for the reply.
            But I want to Check number of TIFF files in a folder (For E.g 100 files). If the TIFF compression not equal to NONE It should give Error. Script is Working with the single file.
            I tried for Multiple files like this. But results nothing. Can you help you in this.
            Code goes here:
            #target photoshop
                                var file = app.open(currentFile);
            try{
            var result = '';
            return result;
            Thanks in Advance,
            Regards,
            Suresh.N.
            • 3. Re: get tiff compression type
              c.pfaffenbichler Level 9
              Does this help?
              // tif compression check by philip cord;
              // 2015, use it at your own risk;
              #target photoshop
              var files = selectTiffFile(true);
              var theErrors = new Array;
              for (var m = 0; m < files.length; m++) {
              var thisFile = files[m];
              if (getTifCompession(thisFile) != "none") {theErrors.push(thisFile)}
              alert("these files are compressed\n"+theErrors.join("\n"));
              ////// select file //////
              function selectTiffFile (multi) {
              if (multi == true) {var theString = "please select tiff files"}
              else {var theString = "please select one file"};
              if ($.os.search(/windows/i) != -1) {var theFiles = File.openDialog (theString, '*.tif;*.tiff', multi)}
              else {var theFiles = File.openDialog (theString, getFiles, multi)};
              ////// filter files  for mac //////
              function getFiles (theFile) {
                  if (theFile.name.match(/\.(tif|tiff)$/i) || theFile.constructor.name == "Folder") {
                      return true
              return theFiles
              // by philip cord;
              try{
              var result = '';
              return result;
