3 Replies Latest reply on Apr 9, 2015 2:13 PM by lindaeliseruble
    Narrow down search to a specific page?
    lindaeliseruble Level 1
      Hello,
      How can I narrow down a search to a specific page in a PDF document?
      For instance, I want to search only page 5.
      How can I do this?
      Is there any documentation that specifically tells you how to narrow down a search to a page number?
      Linda
        • 1. Re: Narrow down search to a specific page?
          George_Johnson MVP & Adobe Community Professional
          What method are you currently using to search? You can use the doc.getPageNthWord to loop through the words on a particular page.
          • 2. Re: Narrow down search to a specific page?
            Actually, I need to find a particular page before I do a search on it.
            My problem is that I need to search a specific book mark in a large document, however, the particular name of the bookmark appears three times and I want to search all three of these bookmarks.
            Currently I am using the following to narrow my search to a specific bookmark:
            if (global.mainDoc.bookmarkRoot.children[i].name.indexOf("XYZ")!=-1) {
            // Do something
            Unfortunately there are three bookmarks with the same name of XYZ and my search only goes to the last bookmark named XYZ.
            I need to know how I can also search the other two bookmarks named XYZ.
            The three same named bookmarks appear one right after the other.  Since I am able to search the last of the same named bookmarks, I would like to then go to the previous page and search that page.  Similarly I would like to go to the previous page before that one and search it as well.
            I could obtain the number of the last bookmark named XYZ, subtract one from that page to obtain the previous page, and if there is a way to narrow a search to a page number I could search that page ,with the bookmark named XYZ, as well.
            Any help is greatly appreciated.
            Linda
            • 3. Re: Narrow down search to a specific page?
              Actually I have solved my problem.  It was quite easy actually.
              I just replaced the green line of code with the red line of code and now all three bookmarks named "Net Charges by Provider" are searched.
                if (global.mainDoc.bookmarkRoot.children[i].name.indexOf("Net Charges by Provider")!=-1) {
              //PMPgs = getBookmarkRange(global.mainDoc, global.mainDoc.bookmarkRoot, i);
                PMPgs.push(getBookmarkRange(global.mainDoc, global.mainDoc.bookmarkRoot, i));
                for (var j in PMItms)
                  global.srchVals[PMItms[j]].srchPgs = PMPgs;
              Thanks anyway!
              Linda
