2 Replies Latest reply on May 11, 2006 6:07 AM by Newsgroup_User
    DownloadNetThing
    DigitalDesignMedia
      Hi
      I'm trying to download some files using downloadNetThing from a URL and I keep getting error 900. Does anyone know what exactly this means and is there a work around?
      I found this on adobe's site '900 File to be written to is read-only'
      I have tried downloading different files from different URLs and even different domains.
      Any ideas would be really appreciated.
      Thanks Jason
        • 1. Re: DownloadNetThing
          DigitalDesignMedia Level 1
          Ok I finally solved this one...
          I didn't realize you have to specify the file name on the local side; I was giving the local path with out the file name.
          pNetID = downloadNetThing (" http://www.theurl.com/file.jpg", the moviePath & "file.jpg")
          I was using pNetID = downloadNetThing (" http://www.theurl.com/file.jpg", the moviePath)
          Cheers, Jason
          • 2. Re: DownloadNetThing
            Level 7
            > different domains.
            Is there any hint in the server's log? If the server says it did the right
            thing then it is likely the problem really is client-side. Did you give it a
            full path to download the file to?
            (Director's error messages don't necessarily correspond to the problem.)
            Andrew
