4 Replies Latest reply on Apr 16, 2015 3:58 PM by Peter Spier
    Linking captions to index
    Henrik Callerstrand
      I am designing a book that contains hundreds of images. Under each image, I wish to have a number that corresponds to a text in an index/list in the end of the book. How can I achieve this in a practical way?
      I have been trying to figure out a method with static captions with no success (perhaps I'm halfway to the answer?). Of course, I could type everything manually, but then there would be no automatic link between each image and its description. The order – and thus, the numbers – of the images will change many times, as will the texts. Therefore, it's very easy to lose control if done manually by simly typing a number and updating the index. Also, if one image moves, I may end up with a situation where I have to retype not only that specific number, but all of the other numbers as well.I.e., human error guaranteed.
      Hope someone can help me with this issue!
      /H
        • 1. Re: Linking captions to index
          Michael Witherell Adobe Community Professional
          The caption could be done as a paragraph style where you apply numbering to the paragraph style. Then, you could define the text of the captions as paper color, whereas the number could have a character style that defines the number as the ink color black, for example.
          For the list at the end, generate a Table of Contents (there can be more than one ToC in a document) that will act as a end index to the pictures. The gathered paragraph styles will be styled with a new paragraph style named maybe index_to_images and its color can be defined as, maybe, the color black.
          • 2. Re: Linking captions to index
            Henrik Callerstrand Level 1
            Thanks, A few extra tricks were required, but it really helped! Hope I remember the workflow tomorrow.
            • 3. Re: Linking captions to index
              The Table of Contents has worked fine with a little tweaking every now and then. However, I have just run into a weird problem:
              I have eight images on the same page with captions below them. These captions link to the ToC and they show up just fine, only they are in the wrong order. I have cut and re-pasted them in the order I want them and the caption numbering changes automatically to the correct figure. But the ToC still has the sequence mixed up.
              So: The order of the captions in the document is correct, not only positioned correctly in the layout but also placed on the page in the correct order. The ToC doesn't care and scrambles the sequence anyway.
              What to do?
              /H
              • 4. Re: Linking captions to index
                TOC picks up text starting in the upper left corner, then moves down before moving right.
