3 Replies Latest reply on Apr 10, 2015 7:23 AM by resdesign
    What is the snippet for a symbol's XY position?
    LabJack
      I am animating a drag drop game and when all 4 pieces are in the right locations, I need another action to happen.
      But what is the code for the location of a symbol?
      I know it's not getPosition (as that relates to the timeline), and if you put in .css({"position": "absolute", "left": "Xpx", "top": "Ypx"}) then it positions the different symbols top begin with... but still doesn't start the consequent action.
      Anyone know?
      Here is the code I am using currently:
      if(
          (sym.$("Slide").css({"position": "absolute", "left": "45px", "top": "117px"})),
          (sym.$("Rightleg").css({"position":"absolute", "left": "260px", "top": "21px"})),
          (sym.$("Leftleg").css({"position":"absolute", "left": "105px", "top": "30px"})),
          (sym.$("Ladder").css({"position": "absolute", "left": "360px", "top": "16px"}))
             alert("correct");
        • 1. Re: What is the snippet for a symbol's XY position?
          resdesign Adobe Community Professional & MVP
          There are several ways to find the position of an object.
          • with top() and left()
              var symTop = sym.$('Rectangle').css('top');
              var symLeft = sym.$('Rectangle').css('left');
          • with offset()
              var x = sym.$("elementName").offset();
              alert("Top: " + x.top + " Left: " + x.left);
              Note: you will need jquery
          • with position()
              var position = sym.$("Rectangle").position();
              console.log( "x or left: " + position.left + ", y or top: " + position.top );
                    or
              var x = sym.$("Rectangle").position().left;
              var y = sym.$("Rectangle").position().top;
          • 2. Re: What is the snippet for a symbol's XY position?
            LabJack Level 1
            Thanks resdesign...
            Sorry, but would you be able to clarify what those functions above are doing?
            From what I can see, they are just placing the symbol.
            I already have the symbol moving, but need to phrase a snippet that says - if sym.$("Slide") reaches position XY, AND sym.$("Ladder") reaches position AB, then execute command (in this case, alert "correct")
            • 3. Re: What is the snippet for a symbol's XY position?
              Maybe something like this? You find the position of each element and if these positions are these numbers you get the alert.
              sym.$("Slide").css({"position": "absolute"});
              sym.$("Rightleg").css({"position":"absolute"});
              sym.$("Leftleg").css({"position":"absolute"});
              sym.$("Ladder").css({"position": "absolute"});
              // get the position of each element
              var slidePos = sym.$("Slide").offset();
              var RLPos = sym.$("Rightleg").offset();
              var LLPos = sym.$("Leftleg").offset();
              var LPos = sym.$("Ladder").offset()
              // set the conditional for the alert
              if (slidePos.left() == 45 && slidePos.top == 117 && RLPos.left == 260 && RLPos.top == 21 && LLPos.left == 105 && LLPos.top == 30 && LPos.left == 360 && LPos.top == 16){
                alert("correct");
