0 Replies Latest reply on Apr 10, 2015 10:40 AM by Brice Hall
    "transform-origin' with jquery overridden by Animate setting
    Brice Hall Level 1
      Has anyone come across this problem:
      I'm pointing to an element inside of a symbol. The target element's origin setting in Animate are 0% 0%. When the element's parent  symbol is generated, I've written code directing the element's 'transform-origin' point to shift to 100% 0%. I'm doing this because the origin point needs to be set across a series of instances of this particular symbol.
      However, my code is being ignored when previewing the file. Inspecting the element in the browser I'm noticing my code and Animate's settings are both there, with my code being overridden by the Animate setting.
      Is there something I'm missing? Is this a known issue or am I not using the 'transform-origin' command properly?
      Thanks.
