2 Replies Latest reply on Apr 11, 2015 11:38 AM by beh_gras_beh
    XML Export with XSLT
    beh_gras_beh Level 1
      Dear scripters,
      With this little script you can export XML.
      But is there an way you can use an XSLT to export the XML?
      var w = new Window ("dialog");
      var myBut = w.add ("button", undefined, "EXPORT", {name: "ok"});
      var myName = app.activeDocument.name.split(".indd").join(".xml");
      if (w.show() == 1){
          try {
               var myFolder = Folder.selectDialog("Select the folder", "");
               app.scriptPreferences.userInteractionLevel=UserInteractionLevels.neverInteract;
               var myInxfile = new File(myFolder.fsName+"/"+app.activeDocument.name.split(".indd")[0]+".xml");
               app.activeDocument.exportFile(ExportFormat.XML, myInxfile);
               } catch(err) {alert(err);}
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
      XSLT:
      <?xml version='1.0' encoding='UTF-8' ?>
      <xsl:stylesheet version='1.0' xmlns:xsl='http://www.w3.org/1999/XSL/Transform'>
      <xsl:output method="xml" version="1.0" encoding="UTF-8" indent="yes"/>
      <!-- Match everything -->
      <xsl:template match="@*|node()">
      <xsl:copy>
      <xsl:apply-templates select="@*|node()" />
      </xsl:copy>
      <xsl:text>
      </xsl:text></xsl:template>
      </xsl:stylesheet>
      Greetings
