6 Replies Latest reply on Apr 12, 2015 8:53 AM by john beardsworth
    Change where Lightroom stores iPhone photos
    pmr413
      Is it possible to change the default import location for iPhone photos that sync via Lightroom sync/mobile?
      Lightroom is syncing my iPhone photos properly, but it looks like the default location for where it stores the files is in a lrdata file on my main boot drive (C:\Users\Patrick\Pictures\Lightroom\Mobile Downloads.lrdata; I'm Patrick if that wasn't obvious from the link ).  My Lightroom library, however, is stored on a different drive.  I'd like my iPhone photos to go to the same location as my main library - either in the same folder or a subfolder.  Reason: it would work better with my current backup and archiving arrangement.
      Patrick
        • 1. Re: Change where Lightroom stores iPhone photos
          The lrdata file is generated by Lightroom and holds previews of your images. It does not contain your images. I have never downloaded photos from an iPhone, but normal import setup allows you to specify where your images will be stored on your computer. Regardless of where you choose to store your images on your computer, there will always be that lrdata file. It contains previews that includes the adjustments that you make in Lightroom.
          • 2. Re: Change where Lightroom stores iPhone photos
            pmr413 Level 1
            Thanks for your response, Jim.  I have to politely disagree, however.  A "regular" lrdata file - the one associated with an lrcat library file - contains preview data, you are correct.  However, the lrdata file associated with my "Imported Photos" folder for my iPhone contains the images themselves.  I can verify this by right-clicking the "Imported Photos" folder, selecting "show in Explorer," and browsing into the lrdata folder.  All my images are there in their original size.
            I'm trying to avoid a separate Import step for my iPhone photos.  They seem to be on my computer already, just not where I'd ideally like them to be.
            • 3. Re: Change where Lightroom stores iPhone photos
              Well then I guess you know a lot more about it than I do. As I indicated, I have never imported from an iPhone. I am a Windows user, and I don't have an iPhone. Hopefully somebody with more relevant knowledge will be able to help you.
              • 4. Re: Change where Lightroom stores iPhone photos
                @ADelcorde_Hotmail Level 1
                Hi Patrick,
                It's probably because your windows "Pictures" folder is still defined in "C:\Users\Patrick\Pictures\" (which is the default windows setup). If you right click on this location through the Windows File Explorer, you should find a Location tab, and you should then have a choice to move it to your preferred location where you stored all your LR pictures. (I'm supposing then that you agree to define your LR pictures folder as the same as your Windows pictures folder). After that, normally you should retrieve the mobiles pictures under the "<My LR pictures folder>Lightroom\Mobile Downloads.lrdata" sub folder being under your main LR pictures folder.
                Hope it help
                Alain
                • 5. Re: Change where Lightroom stores iPhone photos
                  john beardsworth Adobe Community Professional & MVP
                  You can't change where new files arrive, and I wouldn't try to change it via Windows either.
                  Instead, when you open LR and see new pictures in that "drive" in Folders, just drag them to the folder where you prefer them to be.
