Hi
I would like to know if it is possible to obtain a list of workspace tasks for a user of my choice. In the following code, taken from the relevant quickstart, I am able to retrieve a list of tasks for "administrator" because it is the "administrator" settings specified in the connection properties when obtaining an instance of ServiceClientFactory. If I wanted to obtain a list of tasks for user "greg", for example, is there a way I can do this without having to specify the settings for "greg" in the connection properties? I tried to invoke the setUserId() method of the TaskFilter interface but no tasks are returned for user "greg" in that scenario. The aforesaid user has 3 tasks assigned to him. If I specify the user name and password for "greg" in connection settings, I am able to retrieve his list of tasks successfully. However, this is undesirable because I want to be able to retrieve a list of tasks for any user of my choice, by passing a parameter. Is that possible? Code follows:
//Start of code
import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactoryProperties;
import com.adobe.idp.taskmanager.dsc.client.TaskManagerClientFactory;
import com.adobe.idp.taskmanager.dsc.client.TaskManagerQueryService;
import com.adobe.idp.taskmanager.dsc.client.query.StatusFilter;
import com.adobe.idp.taskmanager.dsc.client.query.TaskFilter;
import com.adobe.idp.taskmanager.dsc.client.query.TaskRow;
import java.util.Iterator;
import java.util.List;
import java.util.Properties;
public class RetrieveTaskInfo {
public static void main(String[] args) {
try {
//Set connection properties required to invoke LiveCycle
Properties connectionProps = new Properties();
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, "jnp://localhost:1099");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL,ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, "JBoss");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "administrator");
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "password");
//Create a ServiceClientFactory object
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
//Create a TaskManagerQueryService object
TaskManagerQueryService queryManager = TaskManagerClientFactory.getQueryManager(myFactory);
//Define search criteria by performing a search on
//Assigned tasks (tasks assigned to the user specified
//in connection properties)
TaskFilter filter = queryManager.newTaskFilter();
StatusFilter sf = filter.newStatusFilter();
sf.addStatus(StatusFilter.assigned);
filter.setStatusFiltering(sf);
//Perform the search
List result = queryManager.taskList(filter);
//Create an Iterator object and iterate through
//the List object
Iterator iter = result.iterator();
while (iter.hasNext()) {
TaskRow myTask = (TaskRow)iter.next();
//Get the task identifier value
long taskId = myTask.getTaskId();
//Get the status of the task
long taskStatus = myTask.getTaskStatus();
//Get the name of process on which this task is based
String processName = myTask.getProcessName();
//Get the task description
String taskDes = myTask.getDescription();
System.out.println("The task identifier is " + taskId + "\n" +
"The status of the task is " + taskStatus + "\n" +
"The name of the process on which the task is based is " + processName + "\n" +
"The task description is " + taskDes);
} catch(Exception e) {
e.printStackTrace();
//End of code
Darren
Views
Total Likes
