3 Replies Latest reply on Jan 19, 2007 6:53 PM by Chunick
    Get TextInput value?
    pete@wiretree
      I have a text input field named TextInput, which is the 3rd member on my cast.
      The initial value of this control is 1.
      When I type a 7 (or any number) in the TextInput box, and then click a control with a mouseup event handler, the function fires:
      put member("TextInput").text
      put member(3).text
      both of which display 1 in the message output.
      How can I get the current value of the TextInput control?
        • 1. Re: Get TextInput value?
          Level 7
          > put member(3).text
          I'm not sure exactly what you're wanting, but if you want to press a
          button and have the text from, say, sprite 1 placed on the message
          board, then do something like this:
          on mouseup me
          member("TextInput").text = sprite(1).member.text
          end
          • 2. Re: Get TextInput value?
            pete@wiretree Level 1
            > put member(3).text
            on mouseup me
            end
            The TextInput has an initial value of 1. When the movie loads, there's a 1 in the TextInput box.
            While the movie is running, I change the 1 to a 2.
            I think click my button that runs the script put member("TextInput").text.
            Instead of a 2, which I would expect to see, I see a 1.
            Does this make sense? Why is this happening?
            Thanks!
            • 3. Get TextInput value?
              Chunick Level 3
              if you're using the flash component then the methods/properites should be called from the sprite and not the member... so, to get the current value from your textInput flash component it should be:
              put sprite(x).text -- where x is the number of the sprite that is the text input.
