1 Reply Latest reply on May 10, 2006 4:15 AM by Dawntay
    reset timer
    daveallen09
      hi folks,
      i have a problem with a timer, i cant seem to get it reset when a button is clicked. Any way of any of use knowing how to get it reset.
      my timer code is the following, it works:
      put 6-(the timer/60) into member("membername")
      if 6-(the timer/60) > 0 then
      go to the frame
      else
      go to marker ("21")
      end if
      thanks in advance
        • 1. Re: reset timer
          Dawntay
          You carnt rest the timers as it is a system generated number. but heres the work around.
          For example if you want a time that waits 30 seconds before jumping somewhere but will be reset on a mouse click.
          global mytimer
          on setmytimer me,
          mytimer = the timer + (30*60)
          end
          on exitframe me (or anywhere else you want to put it)
          go to the frame
          if mytimer < the timer then
          go to frame 25 (or where ever)
          end if
          end
          for your reset button.
          on mousedown me
          mytimer = the timer + (30 * 60)
          end
          just remember to declare mytimer global in every diffrent script.
          Hope this helps
          Cheers
          David
