3 Replies Latest reply on Apr 15, 2015 9:17 AM by BBQ Ribs
    Variable Plain Text QRcode with Multiple lines
    BBQ Ribs
      I am trying to create a variable "Plain Text" qrcode which has multiple lines
      When scanning the qrcode the 3 text lines all appear on 1 line and I am unable to get it to read on 3 separate lines
      My cell in excel is formatted as
      =A3&" "&B3&CHAR(13)&E3&CHAR(13)&C3
      I was hoping it returned a value of
      First Name Last Name
      Company
      ID
      Instead I get
      First Name Last NameCompanyID
      CHAR(13) is the Mac Character Set number for a Carriage Return, however doesn't seem to work
      I also replaced CHAR(13) with "/n" for the new line tag. That does not seem to work either.
      Is there another formula I should be entering?
        • 1. Re: Variable Plain Text QRcode with Multiple lines
          InDesign Variables are esseantially just a single character and cannot break across lines or frames. If you need three lines you need three variables.
          • 2. Re: Variable Plain Text QRcode with Multiple lines
            MW Design Level 5
            The note property can contain line breaks, likely some other properties of a QR code can as well. I haven't tried other than Notes. The new line field needs to begin with a backslash and a cap N, so \N.
            This as part of a sample QR Code:
            nNOTE:I am proficient\Nin Tiger-Crane Style,\Nand I am more than\Nproficient in the\Nexquisite art of\Nthe Samurai sword.
            It will format as:
            I am proficient
            and I am more than
            proficient in the
            exquisite art of
            the Samurai sword.
            This also depends on the scanner used. But here is the QR Code generated with that string in it.
            Mike
            • 3. Re: Variable Plain Text QRcode with Multiple lines
              BBQ Ribs Level 1
              Thanks for the replies.
              I do have 3 variable fields however I am still unable to compile them into a single field with a carriage return.
              Going by the way of notes is only achievable through the vcard format correct?, I'll fiddle around with that
              It may be that I will just have to substitute a CR with a tab
              If I find out any other solutions, I will report back
              Thanks again
