2 Replies Latest reply on Jan 19, 2007 7:08 AM by Johnny852
    Unsupported major.minor version 49.0
    Johnny852
      Hello,
      I've created a small java class that imports:
      java.util.StringTokenizer;
      java.util.Arrays;
      When I try to use it in Coldfusion I receive an error: Unsupported major.minor version 49.0.
      I was thinking that it was caused by wrong compiler - from what I know CF is using version 1.4.2 of java - but most likely I compiled it with 1.4.2.
      Do you know what I can do to make this work?
      Thanks in advance for all answers...
      Here's the error that I encountered:
      "Error","jrpp-2","01/19/07","12:00:14","/coldfusion/ListBuster (Unsupported major.minor version 49.0) The specific sequence of files included or processed is: /webroot/test7.cfm, line: 3 "
      java.lang.UnsupportedClassVersionError: /coldfusion/ListBuster (Unsupported major.minor version 49.0)
      at java.lang.ClassLoader.defineClass0(Native Method)
      at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
      at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:123)
      at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
      at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
      at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
      at java.security.AccessController.doPrivileged(Native Method)
      at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
      at coldfusion.bootstrap.BootstrapClassLoader.loadClass(BootstrapClassLoader.java:215)
      at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
      at coldfusion.runtime.CFPage.createObject(CFPage.java:5783)
      at coldfusion.runtime.CFPage.CreateObject(CFPage.java:5677)
      at coldfusion.runtime.CFPage.CreateObject(CFPage.java:5642)
      at cftest72ecfm1685710219.runPage(/webroot/test7.cfm:3)
      at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:152)
      at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:349)
      at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
      at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:225)
      at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:51)
      at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
      at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
      at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:69)
      at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8)
      at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
      at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
      at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
      at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:115)
      at coldfusion.CfmServlet.service(CfmServlet.java:107)
      at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:78)
      at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
      at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
      at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:257)
      at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
      at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:204)
      at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:318)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:426)
      at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:264)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
        • 1. Re: Unsupported major.minor version 49.0
          Level 7
          > version 49.0.
          wrong java version.
          not if you get that error, double check your java compiler.
          depending on where/how you distribute this, it's probably a good bet to compile
          to the shipping java version of cf. if that doesn't matter so much, upgrade cf
          server to the latest 1.4.x java version (there are bug fixes, etc but mainly to
          handle upcoming DST changes).
          • 2. Re: Unsupported major.minor version 49.0
            Johnny852 Level 1
            Ok. It works. The compiler was ok. The thing that I made wrong was that did not change the extension of the previous jar (only the name) which stored the files compiled with java 1.5. As the result CF probably used files that were wrongly compiled in the renamed jar.
            After deleting it everything went fine.
            Thanks a lot ;-)
